Rv-10 Level Flight Reference?
Jimd
Does anyone know what the level cruise flight reference is for an RV-10? Are the main longerons in the tailcone level in cruise, or the HS mounting area of the tailcone? If this info is in the plans and you can tell me what part of the plans that would be great.
Typically to check level on the -10 you use the door sills but in actual flight, it will vary a bit depending on CG, etc. On the ground with tires normally 8nflated it sits a couple degrees nose high.
