I have experienced that I will need to bolt and unbolt some assemblies several times during construction, which are fastened by self locking plates.
I am a bit concerned, if the strength of the self locking mechanism will decrease the more often you bolt on and off. I have not found any specs. (e.g. K-1000-3 nutplate) on that.
On one hand it sounds even normal that the nutplates would loose locking strength over time, but if so, then it would rather be impractical for servicing parts during maintenance cycles in the future.
Any builders hints and experiences on that are greatly appreciated. I am sure you VAF guys will know best.
Thank you
Thank you
