Draker
DWG14A calls out the following hardware to attach the flap rod end to the flap:
K1000-4 PLATENUT
AN960-416L WASHER
AN936A416 INTERNAL LOCK WASHER
CM-4MS 1/4 C 1/4 ROD END BEARING
Is this the correct order for the hardware? In other words, lock washer against the rod end or lock washer against the flap FL-706B plate? I was planning to just assume that Vans hardware call-outs are always in the correct order, but you know what happens when you assume.
Additionally, the plans specify to use loctite or equivalent to ensure the rod end does not back out of the platenut. Any particular loctite? I was planning to use just regular hardware store blue loctite.
K1000-4 PLATENUT
AN960-416L WASHER
