w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 04-30-2023, 08:39 AM
Wiley Price Wiley Price is offline
Default RV-3 engine question
I just bought an RV-3 less engine. How can I determine what Lycoming model number will fit?
Old 04-30-2023, 08:49 AM
blaplante blaplante is offline
do you have an engine mount?
RV6A in phase 2 as of April 2016
Donation made Dec 2022
Old 04-30-2023, 09:00 AM
Or the logbooks?
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019? (actually 2022) RV-10 N46BX
Old 05-01-2023, 02:24 AM
dlomheim dlomheim is offline
Default RV-3 Engine Question
As mentioned previously, you need to start with the engine mount. Did you get one with the airframe? If so, then you need to align your engine purchase with what you've got already; or a). get with Van's to purchase a different one, b). fabricate your own (A/C Spruce who sells "Dynafocal Engine Mount Rings & Kits").
Doug
RV-3A (O-290G) IRAN/flown/sold
RV-9A (Mazda 13B/FWF)
Old 05-01-2023, 10:51 AM
gasman gasman is online now
Register your RV3 with Vans Aircraft and purchase the buildings plans, it will answer most of your questions.
VAF #897 Warren Moretti
2022 =VAF= Dues PAID
Old 05-01-2023, 11:22 AM
johnbright's Avatar
johnbright johnbright is offline
Default register your AC on Van's Store
If you create an account at Van's Store and register your aircraft with its serial number you will have access to the plans and service information online at no charge.
John Bright, RV-6A, N1921R, at FWF
O-360, 8.5:1, vert sump, dual SDS EFI EM-5-F
Z101 as a template, links
Old 06-07-2023, 11:02 AM
You're welcome ....
Old 06-07-2023, 12:24 PM
N329JR's Avatar
N329JR N329JR is offline
Default RV-3 Engines - From a high level generic perspective
At a very high level, the RV-3 was designed and/or has been generally fitted with Lycoming engines in flavors of O-235, O-290, O-320 series.
RV-3B My RV
RV-6 (Dad's RV)
RV-8 Empennage 95%, Wings 95%, Fuse 18.35%
Old 06-07-2023, 02:28 PM
jrs14855 jrs14855 is offline
Default Engines
With the exception of a few oddball models as well as the 0 320H series, all conical mount four cylinder Lycoming's fit the same mount and nearly all Dynafocal engines fit the same mount.
