New Builder - Which Hardware Bags, Rivet Type???
BradyB
I'm New Here
Hello Folks.
I'm looking forward to building my new 12is kit but feel a bit overwhelmed and somewhat discouraged right off the bat. I'm working on assembling the first part but I don't know which rivets to use. I may be missing something with Van's instructions but I was hoping each section would list the specific hardware & fasteners to use or at least list which hardware bag to use?! How am I supposed to know which rivet type and size to use when assembling parts? See the attached instruction screenshotsScreen Shot 2023-02-26 at 9.12.15 AM.png.
I have the inventory list of course but how do I connect random bag numbers of random hardware to each build section?
Thank you in advance for your help!
Send a message to Van's requesting PDF versions of the packing slips.
With these you can search part numbers and the result should show up on the packing slip with the bag part numbers.
Typically
Typically, there is a parts list with each section of the kit. The first thing that is done is to inventory the kit to make sure everything is there. On the list, bags are broken down by parts contained in the bag.
As far as rivet callouts, the initial page you posted is the first page in the section, and it is typically an overview of the parts in the section. The following pages will detail the construction.
Inventory
Some builders prefer to keep bags and use a packing list as a reference.
Others prefer to inventory and separate into bottles, mini bind, storage totes, etc.
I fall into the latter. My inventory had a column for the location of every item down to rivets. It makes assembly much faster, but inventory will put a big hole in a day.
Strongly recommend buying several parts bin cabinets. You also need a labeler.
Label each bin, in alpha-numeric order, with a part number like AN3-5A. Then go through your hardware inventory list, where it lists the parts in each bag, and learn to identify the hardware and permanently move it from the bags to the bins.
All the manuals and plans list hardware by part number, not bag. Here it is in progress.
These are mine, complete. I think that the RV-12iS at the high school that I mentor will have about as many.
This will save you many frustrated hours.
Dave
A lot of good inventory storage answers from regular contributors here, but most of them aren’t -12 builders….and I think the first question the OP asked is most important. Although I haven’t built a -12, I know that the instructions are incredibly detailed and specific about almost every step - so I think the pictures the OP posted are of opening, overview drawings - once you get into the detailed instructions, it should call out the rivets specifically for almost every hole.
As for storing the parts, there is a religious argument that has been going on for generations over the issue of keeping things in the bags as Van’s sends them or sorting all “like” hardware into storage bins. For something like a -12, with very explicit instructions, I’d get into the project a ways before breaking up the bags, because Van’s instructions might actually reference bags…which would make that the easiest way to find stuff.
Paul
Dave
Thank you Dave and Everyone for the initial responses and welcomes!
I currently have the parts bags in parts drawers, I will have to separate them again by actual parts. I should have done this when I spent the day counting inventory!
I am still at a standstill though, how do know which rivets to use? For example, with Section 6, The Vertical Stab, I do not see a list of fasteners/hardware associated with that section. See the attached screenshot, I do see the bearing listed as "COM 3-5", but how do I know which rivets to use?
Rivets
Look where it says AN470- that is the rivet size and length.
I would strongly suggest you have a mentor help you get started. None of this is complicated but having someone get you off on the right foot will make your life much easier. Join the local EAA chapter, lots of people willing to make sure you get started and enjoy the building of a safe airplane!
I have a friend and an RV builder stopping by this week to answer a million questions! I will be going to my local EAA meet-ups too! Thanks!
Hi Brady,
With the RV-12iS plans, rivet types are never shown on the first page of each section. These pages only show the major parts for each assembly. You need to refer to the subsequent drawings for rivet details.
In the drawing you posted labeled “Figure 4,” you need to use five AN470AD4-7 rivets to hold the hinge together. You can find out how to read the rivet code for AN rivets in Section 5 of the kit instructions and in the Standard Aircraft Handbook that comes with the kit.
Also in Section 5 are drawings of nutplates and blind rivets. These will answer a lot of your questions. Also know that for the RV-12iS, the type of rivet used most often is the LP4-3. You probably received two boxes that contain thousands of LP4-3 rivets.
Hi Brady,
I'll continue to review Section 5, especially as I apply the info reviewed.
Unfortunately, the -12 KAI doesn't not ever reference the bag #. You have to look up the part in the inventory to find which bag it's in.
This is my biggest beef with Van's. They don't cross-reference parts, and they don't list which parts are used in each KAI section. IMO, the first page of the KAI section should have a list of the parts and supplies needed in that section, and the bag or sub-kit they were shipped in.
Fundamentals Class?
Hello Folks.
I'm looking forward to building my new 12is kit but feel a bit overwhelmed and somewhat discouraged right off the bat. I'm working on assembling the first part but I don't know which rivets to use. I may be missing something with Van's instructions but I was hoping each section would list the specific hardware & fasteners to use or at least list which hardware bag to use?! How am I supposed to know which rivet type and size to use when assembling parts? See the attached instruction screenshotsView attachment 38915.
I assume you have taken a Fundamentals Class either from EAA or one of the Build Assist facilities that offer them? Or have you reached out to a local EAA Technical Counselor for some guidance?
If not, I would do one of both before you start on your project. I know it's exciting to get started, but it's even more discouraging to make mistakes and then have to wait to get new parts. In your case, you aren't too far from Aurora, but I still think you need a Fundamentals Class.
Brady, fear not! As you figured out, every rivet is specified (sometimes a group of them, e.g. as "LP4-3 TYP"). The RV-12 instructions are very good at this!
Finding parts: I worked from bags for a few weeks and then moved everything into parts bins, which takes hours, but you'll save more time & frustration later. The instructions don't identify which bag parts are in but the inventory list that comes with each kit does, and will remain an invaluable reference. The hard part, though, is translating between naming systems for washers, bolts, nuts etc., e.g. AN and MS. Your parts bin drawers can have both, which will save time. And yes, buy the labeler. Bonus is you can do the spice jars with it, too.
-Chris
Take a class
You’d benefit greatly taking a beginning builder class from the EAA or synergy.
https://synergyair.com/
(Only two hours from you ! )
Or, at least buy a practice kit and get thru that. I took the synergy course, and really enjoyed it. You can ask them questions and pick their brains all day long.
When I received my first kit, I created a spreadsheet with every part on the packing list. Then as I inventoried the kit, I put the smaller parts in organizers and hung the larger ones in groups from the garage ceiling, writing down the location of each part on the spreadsheet. The small bags I could open and sort sitting at the kitchen table which was much more convenient than trying to do it in the shop. The whole process took about 12 hours, but it was worth it. At each step I found the parts I needed by looking at the spreadsheet and layed them out on the table before beginning. I could focus on the building and not get frustrated trying to find parts scattered in dozens of small bags.
Being organized with the inventory and where you place your tools will save you many headaches over the course of the build. It's time well spent.
One thing that continues to catch me is that rarely Van's makes a small error in the bags, like dropping in washers with an "F0" instead of an "FN" in the part number. It's a simple mistake, but really hard to catch in the inventory unless you know the specifications of every little part. There's also the odd piece that's been revised but the plans haven't been updated yet, but that's usually obvious (-1 appended to the part number, for example.) As long as the packing list matches the part number you're ok.
Regarding the drawings, they're usually very clear once you're familiar with them, but it can take some time and practice. If in doubt, ask for help. They're a lesson on conveying a great deal of information with very little text, but they don't try to trick you. The diagram you posted for example shows that 5 holes have to be final drilled for AN470AD4-7. So that tells you to find 5 holes that are similar to the one pointed out, final drill them to #30 (for AD4) and use AN470AD4-7 rivets to attach all the pieces. This kind of notation is used throughout the plans, so once you're familiar with it, it'll be easy to follow -- not that there won't still be an occasional day when nothing seems to make sense.
Welcome and good luck!
Thanks again, Everyone. I went through the random practice hardware kit yesterday and was successful with my new tooling. BTW, I have built an aluminum aircraft before but it was mainly constructed as an ultralight with tubing and brackets. I built a GOAT Primary Glider if anyone remembers these free plans that Mike Sandlin released. That was a scratch-built kit with simple CAD drawings. It was a lot of fun to fly out on the dry lake beds. https://youtu.be/WlY7YfFFN-s
+1 on the Synergy one day course. I took it last summer and it was excellent, highly recommended!
