w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 05-24-2023, 01:18 PM
ten4teg ten4teg is offline
Default WTB Vans Engine Primer System for Carb Eng
I am in need of one of these if anybody has one they didn't use. an electrically activated solenoid system for priming your carbed Lycoming. Thanks
Contact: tom.gregorski@gmail.com
Old 05-24-2023, 07:19 PM
mike647m mike647m is offline
Tom, if your carb has an accelerator pump like most, just exercise the throttle 1-3 times before starting.
Yes, while cranking!
Old 05-24-2023, 08:00 PM
jaredyates's Avatar
jaredyates jaredyates is offline
Only pump while the prop is turning please!
Old 05-24-2023, 08:37 PM
avrojockey's Avatar
avrojockey avrojockey is offline
+1 on pumping while cranking cold engine then idle to act as choke. As soon as it fires up crack throttle to maintain 1000 rip-ems.
On a normal day it takes about 2 pumps. On a cold WI day it takes at least three unless the fuel in the bowl has warmed up a bit from preheating. 100LL has lower vapor pressure and you need more gas when it's cold to create the needed vapor for ignition.
If the engine was running recently then just crack the throttle and let her chooch.
Primer systems are just another failure point that could cause fire
Tim Holmes
Appleton, WI
RV-9A N904DC
2023 Dues Paid
Old 05-25-2023, 02:52 AM
KatanaPilot's Avatar
KatanaPilot KatanaPilot is offline
Default Primer
I think I have one. Email sent to you.
Krea Ellis
Locust Grove, GA
DA20-A1 "Princess Amelia" - gone home to Amelia Island
RV-7A Phase 2 (Honored to be Van's "Miss July" 2021) - now at her new home in Lakeville, MN
RV-10ER officially an airplane as of 4/5/22! Headed to Evoke 7/17/23
EAA Technical Counselor
Old 05-26-2023, 07:47 AM
Rjk921 Rjk921 is offline
Default Using throttle to prime - not me!
Using the throttle to prime is forcing a large quantity of raw fuel into the carb then into the cylinders. I’ve been taught not to do this due to potential of a backfire leading to an engine fire. A primer injects fuel directly into the cylinders which, l believe, is safer. Just my two cents guys.
Dick K
RV9a
