Just happened to see this thread. I just finished up most of my FWF stuff and I have everything you mentioned stuffed under the hood with the exception of an oil separator. Mines a 390 so the prop governor is on the front, which certainly helped. free up some space on the aft side.
Theres a limit to how high you can move that battery and still get it out of the battery box due to the engine mount tube above it unless you build a battery box that doesn't require pulling the battery up to get it out of the box.
With some careful planning and mockups its doable, but I absolutely wouldn't bolt up anything until the engine mount is on otherwise the potential for interference is quite high.
Theres so much stuff back there that it's kind of hard to capture all the chaos with one photo, but here's a picture of mine. If you want to see anything in particular or need approximate layout measurements shoot me a pm.
Terry
