w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 05-09-2023, 12:43 PM
rph142's Avatar
rph142 rph142 is offline
Default New Engine!
My new Titan IO-370 arrived yesterday . It has 9.6:1 compression ratio, dual Pmags, AFP 150 injector, cold air sump, and most importantly shiny rocker covers. Ill be mating it to a catto 3-blade prop. Props to J.B. at continental for making it an easy process!
Rob Holmes
RV-3B N59LG - Built, Flown, Sold!
Extra 300 N111XW - Flown, Sold!
RV-7
-Emp/Wings Complete
-Fuse 25%
-Titan IO370 w/9.6:1, Pmags, cold air sump, AFP
The minimum number of planes one should own is one. The correct number is n+1, where n is the number of planes currently owned. This equation may also be re-written as s-1, where s is the number of planes owned that would result in separation from your partner.
- Veluminati
Old 05-09-2023, 01:41 PM
Zero4Zulu Zero4Zulu is offline
Very nice! What is the diameter and pitch of your new prop?
Steve S.
Rebuilt RV6A Flying!
Scio, OR
EAA Ch. 292
Old 05-09-2023, 01:47 PM
rph142's Avatar
I’m going with a 66x78 3 blade. I’ve been hyper focused on weight during the build, so I’m hoping a light airframe and high hp will offset the course pitch when it comes to climb rate.
Rob Holmes
RV-7
-Emp/Wings Complete
-Fuse 25%
- Veluminati
Old 05-09-2023, 01:51 PM
Walt's Avatar
Walt Walt is offline
Same engine but with Bendix mags, you're gonna love it!
I suggest you be careful with the timing on those PMAGS, high compression, advanced timing, and a hot engine will narrow the detonation margin significantly. They spec the timing at 20deg on these engines for a reason.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, AFP FI, MTV-9 prop
