w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 04-29-2023, 05:58 AM
MajorSTI MajorSTI is offline
Default Elevator Inboard/Outboard Hinge Doublers
Question for the group... Working on the rear spar for the elevators, the inboard and outboard doublers have 4 holes that do not have a corresponding punched hole in the elevator spar (E-702). There are 8 holes in the doublers and only 4 corresponding holes in the spar. Am I supposed to drill the 4 additional holes into the spar? For further reference, these holes are in each corner of the doublers. Drawings and plans don't mention it (could be that I don't see it).
Chris Sawyer, USAF (ret)
#84031
Athens, GA
RV-8 Empennage: HS, VS, and rudder finished, working on elevators
Wings Kit delivered
www.hucksplace.net
Old 04-29-2023, 09:12 AM
bjdecker's Avatar
bjdecker bjdecker is offline
You "match" drill those holes through the E-702 & E-610/E-611 using the E-00001A & 1B as the guide.
Debur - Debur - Debur
Name:	Screenshot 2023-04-29 at 10.11.28 AM.png
Brian Decker
RV-7 (Flying)
Old 04-29-2023, 05:38 PM
Just as I thought. Thanks!
#84031
Athens, GA
Wings Kit delivered
www.hucksplace.net
Old 04-30-2023, 06:08 AM
Skysailor Skysailor is offline
Default Service Bulletin
You may want to consider installing the service bulletin parts on those outboard elevator hinge locations now while it is very easy. Otherwise, you will need to inspect the spar for cracking at those rivets annually forever. Installation of the reinforcing kit is terminating action for the service bulletin.
RV4
Old 05-01-2023, 06:57 AM
Sam Buchanan's Avatar
been here awhile
Just for clarification, the original poster is building elevators. The service bulletin referenced above is for the outboard hinge brackets on the horizontal stabilizer.
Sam Buchanan
RV-6
