GMA 245R with GTN750xi
marchudson
Hey guys. Lots of information in the GTN installation manual about the GMA35 but nothing about the GMA245R.
Just wanted to make sure that the GMA245R is controllable just like the GMA35 via the GTN750. I know you can control it via the G3X but not sure with the GTN due to it not being in the manual.
Marc
The 245/245R uses the CAN bus to integrate with the G3X, it is not controllable from the 750.
I went back and forth on that one when deciding which to install in my own aircraft, went with the 245R.
Where to mount gma245R
Any suggestions on where to mount the GMA245R. I would like to put it on the shelf behind the instrument panel I built? Will it still operate properly behind there?
