This is a dumb question but,,,,,,, has anyone had a problem getting the floor panels F-830pp and F-831pp to fit into the QB fuselage. If so any solution??? Thanks Eric "Bart" Simpson
I spent quite a bit of time fitting my floorboards. You'll have to bend, curl, file, trim, and generally fiddle with them to get them to lie flat.
Here's a log entry that might help you: Floorboards
(You'll notice, in the photos, that I split my aft floorboards into two pieces each so they'd be easy to install and remove when I need to. This is certainly not required.)
I for one, modified the floor panels into six separate panels and they are a breeze to remove. All have platenuts for easy removal except for the holes in the longerons which I tapped. When I did this about 18 months ago there were several differents threads on this and one of the Yahoo groups.
Thanks for the information, I split the f-831 in the same place as the one in the "KitLog" photo , made a angle out of 040,, rivet one side and plate nuts on the other (looks good) and the F-831 now can be taken in and out a with out a problem ...Thanks ! Now does anyone have a photo of where they split there F-830PP???? Thanks again..
