Update - also missing Q6300 and F6035 in the avionics kit…can someone tell me what bag those are in or where you found them? I’m thinking I may have not gotten whatever bag they are supposed to be in. Also noticed my AOA tube was only 4’ long instead of 14’ - assume that’s wrong too…all kinds of problems today. Have had great experience with the thoroughness of the parts so this is weird for sure.
Q6300 and F6035 were missing for me too. Both of these (and the F6262) should have been included from SteinAir (and not Van's - so they won't be on your inventory list). Thoroughly check your kit, and if you still can't find them contact SteinAir. They should get you taken care of quickly.
While your looking for parts, here are a few more that don't make it on the inventory list:
-Headset Isolation Washers
-All DSub connectors should have thumbscrews
-WH-00137 32" Coax cable, BNC/BNC <-- if you ordered Garmin ADS-B in
-CAN terminator for GMU11 <-- if you have a Garmin system
-X3 Connector Housing <-- Looks like this. pins should already be connected to your harness
My avionics kit came with two tubes. One was 4', and the other 14'. Both were listed on the inventory sheet. And I thought I still didn't have enough... Until I realized that for a Garmin system, you cut the tail kit tubing to a shorter length and then reuse the extra.
One more thing to look out for. 42MiS/U-26 and 42MiS/U-27 refer to a wire "L6029" that should be ran through the roll bar for lighting ground. This is no longer correct. This will instead be grounded with the canopy latch switch. (The electrical diagram does show this correctly, and notes this wire has been deleted.)
