Go Back   VAF Forums > Main > Safety
  #91
Old 10-28-2018, 06:24 AM
Vac Vac is offline
Default Version 3.3 Links
Folks,
Summary of changes to this version is in the previous post on Page 9 of this thread.
Version 3.3 of the transition training manual is now available for download in PDF format here: https://drive.google.com/file/d/1ivN6yp5cj7VvhhK_Etsweu1zh_rwtll1/view?usp=sharing
This update also includes revised gradesheets/gradebooks:
The transition and advanced transition gradebooks have been combined and can be downloaded in pdf format here: https://drive.google.com/file/d/1OQgfmRc9_VJ-y2qnrAcwIMgfbUPjFPyu/view?usp=sharing
The advanced top-off gradebook can be downloaded in pdf format here: https://drive.google.com/file/d/1seV5ZE3eTPmbQqOF0SrbircexLKpSn3c/view?usp=sharing
The instructor upgrade gradebook can be downloaded in pdf format here: https://drive.google.com/file/d/1rx80j4WNiefx3jwpDZt0w_2OBsE3R68N/view?usp=sharing
Note that a “hard copy” of gradebooks are now also included in Appendix D and can be printed from the basic document, if desired.
Instructional briefings are also available for download in pdf and PowerPoint format:
The RV aerodynamics brief in powerpoint format is available here: https://drive.google.com/file/d/0B8EIT6g2n8o_Y3dBUXJQaURwa0E/view?usp=sharing
The RV aerodynamics brief in pdf format is available here: https://drive.google.com/file/d/0B8EIT6g2n8o_WXNzeGd5OF9uSGs/view?usp=sharing
The RV performance brief in powerpoint format is available here: https://drive.google.com/file/d/0B8EIT6g2n8o_VXdjRGc1bUxmRms/view?usp=sharing
The RV performance brief in pdf format is available here: https://drive.google.com/file/d/0B8E...ew?usp=sharing
The RV weight and balance brief in powerpoint format is available here: https://drive.google.com/file/d/0B8EIT6g2n8o_dmNhQ2tUcUozTjQ/view?usp=sharing
The RV weight and balance brief in pdf format is available here: https://drive.google.com/file/d/0B8E...ew?usp=sharing
As always, if anyone wants a Word version of manual, drop a line to vacf15 at yahoo dot com and I’ll be happy to send one.
Vac
Mike Vaccaro
RV-4 2112
Niceville, Florida
Old 10-28-2018, 07:11 PM
flyinhood flyinhood is offline
Thanks Vac!
46 Luscombe 8a Rag Wing, Armstrong starter
RV-6, IO-320, Catto, G3X Panel (Thanks Walt!)
Old 11-02-2018, 06:38 AM
Crewser1989 Crewser1989 is offline
Default Thanks!
This is really amazing! My RV-4 is in the shop and should finally be done when I get back stateside and this has been some great study material. I am feeling more confident about my GK and expectations of the plane for when I finally take it up for the first time! I just wanted to say thanks for putting this stuff together and posting it!
Old 11-30-2018, 10:39 AM
Eddie P's Avatar
Eddie P Eddie P is offline
Hello Mike (Vac)! Your work here is outstanding. This perspective brings a very high level process to the home-built flight training community that has flexibility to be de-tuned or adapted easily when needed. The key here: The instructor to student interface is the part that matters "to the end user". I know it can be hard to visualize that part just by reading an instructor syllabus. Recreationally motivated but professionally minded pilots (the kind that tend to like to fly RV's) do not have to viscerally understand the "behind the curtain" ways and means of a program like this to benefit from it greatly. With the help of good instructors, a quality product can be consistently provided with, I suspect, excellent quality control and quantifiable results, using your courseware. This is the secret sauce of any good community based organization like the Bonanza Society, etc.
I downloaded these programs and I'll keep a hard copy of this great work handy for BFR's, training hops, etc. Thank you so much for sharing your great work, put nicely into a tidy, organized format!
Flying is Freedom
RV-8: IO-360, WW RV200 CS Prop, P-Mag-Slick Combo, Advanced EFIS 3500
Old 04-29-2019, 10:34 AM
Vac Vac is offline
Default AOA Training Resources
Hi Folks!
In an effort to build academics for our angle of attack project web site, I've put together four short essays that describe the basics of the AOA tone, how to use those references for takeoff and landing, basic energy management considerations and how to use the AOA logic when the engine quits. Since the transition training manual references ONSPEED AOA and L/Dmax when appropriate, I thought I would offer these essays as an additional resource for folks that are interested in learning more about angle of attack and how to apply that during everyday flying. Even if you don't have an AOA system in your airplane, the tone allows you to follow along in the videos if you are interested in learning more about the concepts. If you do have a calibrated AOA system and have accurate displays for ONSPEED and L/Dmax, then the material might offer some insight into how to apply those two key AOAs during some of your flying.
The essays are in pdf format for display on any device and they have imbedded hyperlinks, including video demonstrations.
What is ONSPEED? A description of the ONSPEED concept: https://drive.google.com/file/d/1q9K...ew?usp=sharing
Takeoff and Landing Using AOA References. When we land a fighter, we use AOA as the primary reference for energy management during approach and landing. This is how that concept translates to an RV: https://drive.google.com/file/d/1ZTK...ew?usp=sharing
Introduction to Energy Management. An overview of energy management and how AOA dovetails with that topic when operating in certain parts of the flight envelope: https://drive.google.com/file/d/1Ewt...ew?usp=sharing
Using AOA When the Engine Quits. A power-off glide is a great way to learn about energy management, and accurate AOA displays (or tones) can be useful maintaining aircraft control when you have a power loss:
https://drive.google.com/file/d/1e1e...ew?usp=sharing
As always, I'm looking for suggestions on how to improve or correct any of the training resources, including this material. If you have any ideas, suggestions (particularly on how to improve the videos or the articles) or questions, please drop a line or post!
Fly Safe,
Vac
Edited: Ouch, just realized (30 April) that one of the diagrams in the last paper was incorrect (the ONSPEED "push/pull" model)! No excuse. Diagram is corrected and original link replaced with link to corrected document. Also, over time there will be corrections and edits made to the associated documents. I'll update linked pdf files as that occurs. 15 May 19 Note: found error with emergency turn back discussion in "unload for control" essay, corrected diagram and verbiage. 24 May 19 Note: Small grammatical corrections to all documents. Revised Fig 8 and emergency return after takeoff discussion in "Unload for Control" essay. Updated links to current versions.
31 May 19: Revised emergency turn-back after takeoff discussion in "Unload for Control" article based on flight test. Flight test video is available here for those interested in learning more about using AOA to assist with EM for emergency turn-back: https://youtu.be/K1UlEi_Ew30. Note that minimum turn back altitude is aircraft and condition dependent; and parameters in the video are only applicable for the airplane utilized for test under test conditions.
3 Jun 19: Revised "What is ONSPEED" essay.
23 Jun 19: Revised energy management and using AOA when the engine fails essays. Repaired link.
2 Sept 19: Add link to five minute briefing for turn-back test/demo: https://youtu.be/U1T-ePy9e94
Mike Vaccaro
RV-4 2112
Niceville, Florida
Last edited by Vac : 09-02-2019 at 08:00 AM. Reason: Correction to linked documents
Old 12-29-2019, 08:05 AM
Vac Vac is offline
Default Stall Spin in the Base Turn Video
Recently there was some excellent discussion regarding slipping RV's that evolved into discussion about stalling while slipping. As a result of participating in that thread, I thought it might be helpful to put together a short video demonstration of slipping and skidding "departures" (the airplane doing something I don't want it to do) in the base turn:
https://youtu.be/_5xntbFSHf0
The demonstrations in the video illustrate the discussion in the training manual in the Handling Characteristics section pp. 342-333 and Confidence Maneuvers section pp. 390-391.
Standard notes/warnings/cautions apply: For the demo, the airplane is loaded within Van's aerobatic weight and CG limits for the RV-4. Also, as stipulated in the manual, the RV-4 experiences fairly significant horizontal stabilizer buffet during a skidding departure.
Fly safe,
Vac
Mike Vaccaro
RV-4 2112
Niceville, Florida
Old 12-29-2019, 05:42 PM
Jeff Vaughan's Avatar
Jeff Vaughan Jeff Vaughan is offline
Thanks Vac
The Onspeed AOA tones really helped me follow what was happening
Keep up the good work
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
2021 donation current
Old 12-29-2019, 08:20 PM
Blain's Avatar
Blain Blain is offline
Excellent Mike. Thanks for your efforts.
Blain
R-22 sold.
RV-8 AW Cert 02-09-17
N82 Sierra Tango
Avatar courtesy of AircraftStickers.com!
Dues gladly paid thru Nov. 2021(my reminder)
Old 12-30-2019, 08:33 AM
kevinsrv7.com's Avatar
kevinsrv7.com kevinsrv7.com is offline
Thanks Mike for putting that together. Explained well.
Old 04-15-2020, 09:18 AM
wawrzynskivp wawrzynskivp is offline
Default Comprehensive and Valuable Resource!
Thanks to VAC for all of this hard work!
Here is a document with outstanding structure and content. Any flight instructor considering transition training could very well get whatever they need from this one source for syllabus structure.
Having had written my own syllabus for a LODA application I appreciate everything that this document has. Even the Motherhood issues such as ADM, RM, SRM are properly embedded throughout.
The inclusion of solid AoA flying skills then sets this method head and shoulders above standard approaches to energy management.
Vac's willingness to let all of us copy and use this material as our own is invaluable. This is intellectual property that is actually worth something.
Thanks Vac!
