What's up with those two holes at very top of the F1202-E? I'm at the end of Sec. 23 and have looked ahead a little bit but I can't come up with any clear answer as to what those two holes are for at the top of the part. My best guess at this point is that they just provide some clearance for a rivet or hardware that installs to the top of the longeron through a hole that gets match-drilled later? Or...tooling holes for the bending of the part? Did I miss a step where that is explained?
I have included the KAI page, but you can't see the holes. They are on a flange bent forward at the top of the F1202-E. Imagine two more holes in the Longeron and they would be right below those.
