Go Back   VAF Forums > Model Specific > RV-4
  #11
Old 03-01-2021, 08:18 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Originally Posted by Toobuilder View Post
That is an OWT that started back in the radial days. If Im going somewhere cross country the throttle is advanced to the stop on takeoff and not touched again until on the descent. Power is managed with RPM and mixture, just as David suggests.
We fly our fuel injected airplanes the same way - and the only difference with the carbed ones is that we pull the throttle back just a smidge to make for better atomization in the fuel/air charge due to the tilted throttle plate. But for all intents and purposes, thatís WOT as well.
Interesting results of some prop testing I have been doing regarding RPM. If you are looking for the best SPEED while the throttle is WOT, I have found that the higher you go, the more our props (both two and three blade) like 2500 rpm for attaining the best TAS. Above that, or below that, speed drops off by a few knots. AT the standard 8,000í DA that Vanís uses for airplane comparisons, the two blade BA prop tends to keep goign faster (by just a little bit) at higher RPMís until you hit redline (I have no idea what it does above that!). The three blades peak speed is still found at about 2500 RPM however.
Iím working on getting the data ready for publishing in the near future.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 03-01-2021, 08:33 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
SNIP
Interesting results of some prop testing I have been doing regarding RPM. If you are looking for the best SPEED while the throttle is WOT, I have found that the higher you go, the more our props (both two and three blade) like 2500 rpm for attaining the best TAS. SNIP
Paul
+1. Above 8Kí or so I find 2500 RPM, WOT, 10-20 degrees LOP to be the sweet spot (RV-8, IO-360-M1B, Hartzell BA prop). Typical economy cruise is 173kts TAS, 7.5 GPH. During the winter I found running at this point the CHTs are to cold - below the 350 degree target to minimize stuck valve issues. To compensate and keep CHT up 350-360 degrees I tend to run at PEAK, burning 8.5 GPH but bumping up speed to ~180kts TAS.
Carl
Old 03-02-2021, 08:25 AM
Dayton Murdock's Avatar
Dayton Murdock Dayton Murdock is offline
Hi All
My current settings are:
20" MP 2360 to 2400 RPM 8.5 GPH with these settings my TAS 180kts @10.500'
Dayton Murdock
VAF#408 RV4 N359DM O360 C/S, Dual P_Mags, AFS Efis, Trutrak A/P, Leather, Electric trim and flaps, Led lights, Freeflight ADSB and it is painted Red, Flying 1105 hrs 11/28/20
Builder Log
Old 03-02-2021, 10:32 AM
smithflys23 smithflys23 is offline
This is an interesting thread. Iím new to CS prop operation, and I was told that the power lever, should never be forward of the prop lever. Iím learning some things after reading this thread, and the linked articles.
I understand what has been said for climb, cruise power/prop settings, but what about aerobatics? Iíve been using 26Ē mp, 2600rpm, and full rich. Any suggestions on where power and prop should be set for aerobatics from 2-3000í?
Old 03-02-2021, 10:36 AM
Bicyclops Bicyclops is offline
Am I the only one oversquare?
Ed Holyoke
Click image for larger version
Old 03-02-2021, 10:51 AM
Ed Holyoke
I understand the lower RPM reduces engine pumping losses - so the engine is more efficient. My experience however is that the plane is slower at lower RPM for the same fuel burn. I equate this to propeller efficiency not being constant across air speed, altitude and RPM ranges.
For the Hartzell BA prop, my experience is that at altitude the prop/engine ďsystemĒ seems to like 2480-2500 RPM as an operating spot where the power put into the prop produces the most thrust (or for the system the fuel burned yields the highest MPG for a given speed). Perhaps others have different experiences.
Iíve flown behind constant speed props that take all the engine power but are not great at converting that power to thrust. Props are a blend of science and art.
Carl
Old 03-02-2021, 11:21 AM
Carl
I can't find a screenshot, but the same day I was seeing the same airspeed, same altitude, same fuel flow, similar CHTs at 2400RPM. The only difference I could see was that I was spinning the engine faster. Perhaps the prop was slightly more efficient at that RPM and was being offset by increased pumping loss.
I rarely set cruise power for max airspeed, mostly going for LOP and CHTs under control. Mine is a Whirlwind 74RV on a 10:1 parallel valve IO-360 in an RV-6 for reference.
Ed
Old 03-02-2021, 02:59 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
This is how OWT's are born.
There is no logic nor science behind such a claim. I would not only suggest you just forget this and fly LOP all year round, but strongly urge you not to promote more OWT's.
My mate Mr Deakin and co, will surely be having a fit. Walters ashes will be churning in his urn too.
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Old 03-02-2021, 03:05 PM
RV10inOz's Avatar
Paul
Paul, you are not alone here. I have found that to be true also, and with the 2 blade BA props, one VAF member whose name I can't recall (RV10 owner and ag pilot from Georgia) told me in a PM once that in his racing around the countryside he found that something like 2650-2675 he gained the best from his prop.
No doubt you will be more precise in data collection.
Something I am not happy about, recently doing side by side comparison with a Whirlwind 2 blade, the other pilot who must have been cheating somehow he was 6 knots faster on GS given the same air, same everything. SO the WW guys have pulled some speed out of the -10 for their efforts.
I can't wait to see what you come up with.
David Brown
Old 03-02-2021, 03:45 PM
David,
Sorry, but you are dead wrong.
I suggest you watch this Mike Busch video on why valves stick. It provides clear explanation as to why we should strive to maintain CHTs between 350 and 400 degrees.
https://youtu.be/7ohsVvYbAaQ
Carl
