Old 03-02-2021, 04:54 AM
vic syracuse vic syracuse is offline
Super Moderator
Originally Posted by mckes View Post
Hi Vic, which style coils are you using? For those wondering about the standard lightspeed triumph coils I believe Klaus is the cheapest so youíre best off going through him. Iím just trying to find out what the larger/heavy duty coils actually are before getting replacements and wether people have had success as thereís no real info on them. I have just heard people referring to them as GM coils.
Sam
They are the new coils provided by Klaus.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 03-02-2021, 06:56 AM
bjdecker's Avatar
bjdecker bjdecker is offline
Originally Posted by RV8JD View Post
A buddy did some research on replacement coils for his original LSE Plasma III coils (in talking with Klaus) and came up with this Nology P/N: 152 051 350, PFC-30D, for 3.0 Ohm Systems (Electronic Ignition - 2.4 Ohm Actual). Don't know if Klaus agreed or not.
Would both choices work with the Plasma III?
Attachment 8945
Per the LSE manual, the input resistance should be ~ 1 Ohm, the coils listed don't meet that specification.
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Tailcone & Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
Old 03-02-2021, 07:33 AM
Lars Lars is offline
Default new vs old
The new coils are larger and require different mounting brackets. Different vendor, supposedly higher output.
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
Old 03-03-2021, 05:12 AM
deek deek is online now
Originally Posted by krwalsh View Post
I have had luck with PIDG connectors for both the core and the shield of the RG-400. I used a solder sleeve onto the shield braid instead of the "strip it back and twist it" method. The solder sleeve has a pigtail that I then crimped the PIDG onto. The center core was backed up with heat shrink and the coax supported close to the coil. So far so good.
^^^ Excellent!^^^ Good installation practices and securing the RG-400 (not solid core as Klaus initially provided decades ago) to prevent vibration and relative motion is key to reliability. I have almost 6,000 hours aggregate on five LSE systems with no coax/connector failures; one coil failure. I might own the coil failure; the coils are mounted to crankcase upper spine which is on the hot side of updraft EZ's
'83 LongEZ - N888EZ 3,671 hours
'89 LimoEZ - N26EZ 686 hours (sold)
A couple of Glasairs and a Lancair 320...
Next: a RV14 need something to build
Old 03-03-2021, 01:01 PM
nharris nharris is offline
Originally Posted by kaweeka View Post
I had a coil failure of my Plasma III ignition last weekend returning from San Diego. My aircraft has 719 hours and this is the first problem with my Lightspeed ignition. I measured the resistance of the output coils and indeed the one for cylinder 3,4 lower plugs was well out of spec (7.5kOhms spec and 1.3MegaOhms measured). I called Klaus and he send 4 new coils at my request. The new coils are completely different in form and appear to be 0.5 Ohm dual output coils from Dynatek. They make high output ignition systems for motorcycles and ATVs. I needed to make new mounting brackets which was not a problem. Luckily, the existing wires fit. What I didn't expect was the positive lead on the bad coil had broken. Klaus uses coax cable and the positive lead is a solid copper wire. I'm not sure if vibration broke the solid wire and if that fried the coil. I'm not an engineer! Additional new tidbit while speaking with Klaus was the difference in spark plug gap with the new coils. Higher output and duration of the spark he says needs a larger gap at .040". My back went out today while I was working on this so I'll update when I can move.
kaweeka do you have a picture of how you mounted these new coils and the brackets you made?
I just upgraded my system and was surprised to see a new style coil, my old setup had the coils mounted to the top of the case.
Old 03-03-2021, 01:08 PM
kaweeka kaweeka is offline
I would be happy to if someone would refresh me on how to post a picture.
RV-9A N435KR, Vans calendar March 2018
LIO 320 B1A, Dual LS Plasma III, AFP injection
G3x touch
Roseville, Ca
Old 03-04-2021, 06:03 AM
Click image for larger version
Hopefully this picture uploaded. As the coils are a bit larger, the ones on the firewall extend down slightly further than previous. I'm not sure how that will affect removing the oil filter. Luckily, the existing wires fit the new installation. I replaced the NGK with the Denso as Klaus suggested and gapped to .040". Started up very quickly and ran smoothly.
G3x touch
Roseville, Ca
Old 03-04-2021, 09:04 AM
theduff theduff is offline
Default GM coils.
Sam
I have a set I got from Klaus sometime back but never used them. If you get me an email address Iíll send you some pics.
Duff
RV-4S (slider) Builder and 1300 hr RV Pilot
Old 04-02-2021, 04:53 PM
Robb Robb is offline
What is the OHM rating on the old style coils?
F1 EVO
Aviat Husky A1B
Old 04-02-2021, 04:57 PM
I cannot see what the actual mag drop is on my 540 when doing a run up on my GRT display. I do know its rougher that my standard Slick mag. I did a simple in flight mag check and it is indeed rougher than my mag. I have new plugs in it and normal EGT's just curious what others experience. I have the older lightspeed with original coils and new wires
F1 EVO
Aviat Husky A1B
