Old 03-02-2021, 06:34 PM
emsvitil's Avatar
emsvitil emsvitil is offline
Default Flaperon Linkage
This is a curiosity question.
I'm trying to visualize how the flaperon mixer / linkage works.
So I'm looking for a visual diagram of the system.
thanks
Ed
Old 03-02-2021, 09:22 PM
NinerBikes NinerBikes is offline
$10 buys you a Van's Rv-12 KAI memory flash stick, with all the plans and schematics on it, when building. It will have on it what you're looking for. Other option is find a local RV-12 that's going under an inspection annual, and ask to take a look when everything is opened up.
Donated
RV-12, #212 N72DJ, bought flying. A Blessing in disguise. Thank you Double D!
Old 03-02-2021, 10:17 PM
DHeal DHeal is offline
Here you go:
https://www.vansaircraft.com/wp-cont...1/RV-12_32.pdf
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 1,020+ hours (as of Apr 2021)!
VAF donation through June 2021.
Old 03-02-2021, 10:29 PM
mikefox mikefox is offline
thanks
I agree the Kit Assembly Instructions do a fantastic job of showing exactly how it works.
I’d also suggest looking at build logs from the many talented builders on vansairforce.net or search with google for a popular build log software. And google should also reveal builder videos too.
If you are near the Bay Area, let me know as I can show you the 12iS I helped build and fly.
Hope that helps.
Remember, Red, hope is a good thing, maybe the best of things, and no good thing ever dies. I will be hoping that this letter finds you, and finds you well.
Old 03-03-2021, 07:14 PM
First time I learned about “mixer” linkage for flaperons was building an RC model as a teen.
Old 03-04-2021, 04:47 AM
mwjohn63's Avatar
mwjohn63 mwjohn63 is offline
Ed,
I had the same question when I was staring at the flaperon mixer assembly...how does this thing work? I found this video that shows the mixer in action...makes more sense now
http://www.youtube.com/watch?v=q3tgNePK9AM
Flying RV-12 (190+ hrs and Oshkosh 2019)
N418MJ
Warren County, OH (I68)
mwjohn63@gmail.com
http://www.mykitlog.com/mwjohn63
https://www.youtube.com/watch?v=EJdXcjckN6M
