alpinelakespilot2000
Is this an OK position for my fuse blocks?
I know a lot of people mount them on vertical surfaces, but is there any issue with mounting them on the back of the panel where, theoretically, the fuses could fall out of the blocks since the panel slopes slightly forward. I can't imagine that the fuses actually would have any tendency to fall out, because they insert very tightly, but I couldn't find anyting in 43.13b or elsewhere re: best practices on this.
The reason I'd like to have them attached to the panel is because I'm fabricating a pull out/tilt-down panel. The more I can keep wires attached to the panel, the easier this is.
Thanks for your thoughts.
