Skyview and Tosten Grip Wiring - CS8
Lynnb
I'm working through the wiring diagram for the Tosten Grips and there are two common wires (Green and white). One appears to ground the trim switch/hat and the other to the other 4 switches. Since I'm using the skyview system I know I don't need to use a relay deck, this is built in already. But what I'm not sure about is can I just ground both of the common wires (green and white) together and to a common ground, or do I need to do something else?
Lynn
Tie the grounds together and to the same common airframe ground reference, just as you suggested. All good.
Grounds
Lynn,
Yes you can. On the Dynon system, everything that you activate is just connecting the signal wire to ground, so attaching both of those common wires to ground will work.
Brian
