Old 01-17-2018, 09:39 AM
kentlik's Avatar
kentlik kentlik is offline
Default Slow but steady
Some triming still needed on this cover
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 01-17-2018, 09:42 AM
kentlik's Avatar
Default Back up a little
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 01-18-2018, 12:59 PM
kentlik's Avatar
Default pivot point moved a bit
New offset for actuator
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 01-19-2018, 08:38 AM
kentlik's Avatar
Default trim
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 01-19-2018, 08:40 AM
kentlik's Avatar
Default Installed
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 01-19-2018, 06:49 PM
kentlik's Avatar
Default firewall
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 01-28-2018, 05:06 PM
kentlik's Avatar
Default Firewall penetration hack
Got this idea from VAF contributor, worked great. If my memory was better I could tell you who it was, but it's not better...
Cabin heat setup cover
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 01-28-2018, 06:37 PM
cajunwings cajunwings is offline
Originally Posted by kentlik View Post
I have found this to be the case for the entirety of the rebuild. At times I get lost trying to figure out what to do next and have to spend copious amounts of time in the manual getting on track.
Just thought I would let you know you were correct!
You are making really good progress and are doing high quality work. Sometimes when you get to the ?what to do next question? you just have to pick something that needs doing and press on assuming it all needs to get done sooner or later. I?m about at the 80% point and so far have not painted myself into a corner. My reality is that I?m too busy to work on mine very often.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
Old 01-28-2018, 08:38 PM
kentlik's Avatar
Originally Posted by cajunwings View Post
You are making really good progress and are doing high-quality work. Sometimes when you get to the ?what to do next question? you just have to pick something that needs doing and press on assuming it all needs to get done sooner or later. I?m about at the 80% point and so far have not painted myself into a corner. My reality is that I?m too busy to work on mine very often.
Don Broussard
57 Pacer
Don,
Thank you for the kind words! They mean a lot to me. Sometimes just a note on here, even if it is that the photos are not coming through, is something! I now work pretty much solo in the evenings, gets a little lonely, lol. I took almost all of 2016 off working, so I redoubled my efforts in 2017 to try and make up for it! I really need to get my motor disassembled and take an inventory of what is bad...a little apprehensive about that. Wing repair after I get the fuse ready to hang the engine...
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 02-02-2018, 06:20 PM
kentlik's Avatar
Default crankshaft plate for engine stand complete
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
