Is anybody clutching their chest on this one? I've got 600+ hours now, all on COSTCO av fuel with no issue. I fly 2x week minimum and just put new hoses on. I did not see anything new to worry about but am curious if anyone is changing their fuel regime.
Steve at LNA (Lantana, FL)
Flying a built ELSA
For what it's worth: someone told me some years ago that after further investigation only BP puts very little ethanol in it's gasoline - I buy BP 98 for my bird since then (Europe, ULS engine)
Hans Labruyere
build & sold project Kitfox IV
Project bought & flying RV12 #120742
You can buy inexpensive ($10USD) test kit to determine % alcohol in auto fuel...
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 830
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
I use Costco premium exclusively except when on trips. Every 6 gallon jug is tested for alcohol content, it always runs between 6-8%. On trips if I can find auto gas close to the airport I always test it before pouring it in. The plane during my ownership has flown 725 hours in the past 35 months, a little north of 3000 gallons. I am based in SoCal with typically very HOT summers. Only once I suspected a situation similar to vapor lock and can't be positive. I always purge the fuel system with the electric pump before starting. I believe that is very important to pushing the heat soaked fuel out and keeping cooler fuel in the lines to the carburetors.
I have my Dynon set to alarm me if the fuel flow drops below 1.8 GPM. If I was to get this alarm it would mean a potential vapor lock situation. In testing (on the ground) at full power and turning the fuel valve off the engine will run for 15 - 20 seconds. In theory if I got the low fuel flow alarm I would have 15+ seconds to make a plan for landing, that's a lot of time in an emergency.
__________________ Live as if you were to die tomorrow. Learn as if you were to live forever.
visit my blog - http://waltsrv12.com
-- Walt --
