Hi folks,
scratching my head here (RV 8A slow build fuselage). The instructions say to countersink the 9 central holes in the bottom of the lower angle on the firewall assembly and dimple the corrseponding holes in the foreward floor panel. So far so good, but the the outer holes of the 9 holes are also shared with the F-893 floor ribs. The material of the floor ribs is too thick for dimpleing, but requires countersinking. So what's the story here - countersink the two holes in the floor ribs and leave the corresponding holes in forward floor panel and lower angle alone (i.e. not countersunk or dimpled)?
Also, if the cooling air ramp is later on installed, wouldn't there some shiming required for the 7 holes in the middle, since the cooling air ramp sits on the flanges of the floor ribs as well?
Kinda lost here - appreciate your help.
Thilo
Thilo
