All,
I've been experimenting with my G3X autopilot the last couple of flights, specifically flying VOR to VOR and culminating in an ILS approach with a procedure turn. Any inputs / suggestions from folks who use VORs and the G3X AP would be appreciated!
I set up the autopilot in heading mode, to intercept VOR#1 on a specific inbound radial using the OBS function. The autopilot flies the heading and intercepts the radial and heads inbound. I have the inbound course set and then toggle off the OBS to allow the remaining flight plan to proceed (unsuspend).
I purposely chose the inbound radial so that the AP would have to make a turn to acquire the outbound radial. Going through the cone of confusion, I switch the course to the outbound radial. The AP tracks that fine.
Once I reach the switch over to VOR#2 point (the course remains the same, I should just go from outbound VOR#1 to inbound VOR#2), I swap the frequencies and I get a tone in the headset. I figured this was just letting me know that I swapped frequencies. Slowly my course drifts off the radial... turns out, the AP disconnected NAV mode and went to ROLL mode. I saw the amber ROLL indication, and it didn't dawn on me that I had dropped out of NAV. Pushing the NAV button, the course never attempted to get back on the set course.
When I got close to the VOR I switched to the outbound radial and the AP tracked that to the IAF. I switched from VOR#2 to the ILS freq but forgot to arm APR mode and blew through the IAF, so I hand flew around the hold and then let the autopilot capture and fly the ILS down.
So here are my questions:
1) Dropping out of NAV when changing VOR freqs. Why does it do this and is the proper response to just reactivate NAV mode?
2) After reselecting NAV mode, it didn't capture the course which was set. Do you have to steer to a heading which crosses the desired radial in order to reintercept it? (because the AP didn't seem to know where to go at this point)
3) At what point should you arm APR mode and select the LOC freq, right before the IAF? Based on switching VOR freq, seems like no matter what you do the AP is going to change AP modes.
4) If you are flying inbound to the procedure turn using the VOR, will the AP fly the hold and what does it use to do that, GPS or some other logic?
Other Observations:
The GTN simulator won't track a heading to and intercept an OBS course. You can set it up but have to fly it manually.
Very little info is available about VOR usage. The Garmin system seems to be really dependent on GPS navigation. The one training example I found was GPS inbound to the ILS, which then flew the hold and captured the ILS... this worked well for me on for this same approach.
In the G3X, I have the PFD on the left of the split screen. The right knob function can be set when you are in full display mode. The left knob is always Heading and Altitude. I have the autopilot control panel and have been training to always use those knobs instead of the knobs on the display. I wanted to set the knob to Course/Baro but when the split is on the right, it has to be the page control. So I'm stuck with two sets of knobs to set heading and altitude (G3X and AP panel) either have to touch the course box to set the course or unsplit the screen to change the course. Why can't we select the left knob functionality in the config menu like we can the right?
Other Observations:
