Old 09-07-2020, 07:56 PM
mturnerb mturnerb is offline
Default Setting Horizontal Stabilizer Angle - Tip
Looking at this part of the plans, and trying a measuring tape at first, I found it difficult to get consistent measurements solo.
So I came up with what may or may not be a unique solution. I took a piece of wire and crimped a ring connector on it, then secured it to the center forward rivet hole and measured the distance and made adjustments. I was careful to twist the connector to point in the correct direction.
Connector/wire:
Using small piece of tape to mark exact position at each corner:
Name:	Screen Shot 2020-09-07 at 9.49.22 PM.png
ID:	2152  Click image for larger version
ID:	2153  Click image for larger version
ID:	2154  Click image for larger version
Turner Billingsley
RV-14A built/sold N14VB
Old 09-08-2020, 09:44 AM
iwannarv iwannarv is offline
Good way to use those new-found crimping skills! I think I'll use this technique - I was wondering what to use as to not get any stretch/unwinding in whatever string material I was going to use.
Brad Brensing
RV-10 Emp/Tailcone - Complete, QB Wings - Complete, Fuse - Complete, Finish Kit - In Progress.... (Doors )
Never judge a man by his trim tabs.
Old 09-08-2020, 10:05 AM
flion's Avatar
flion flion is offline
Drill a #40 hole at 1" mark on a tape measure and cleco it in place. But I have to admit, I like this method, too. Clever thinking.
EAA Technical Counselor #5357
Old 09-08-2020, 11:44 AM
Never thought of that - but somehow it would bother me to drill into my tape measure.
Turner Billingsley
Old 09-09-2020, 10:00 AM
rv6n6r's Avatar
rv6n6r rv6n6r is offline
If you have a Harbor Freight nearby you can take a coupon and get a free one. Do it again the next month or week or day, and again... I have like six of them.
Also if you foster an attitude of, "modify to make it work" you will save yourself lots of time and effort over the course of a project. Be willing to innovate, it's freeing!
Randall Henderson
RV-6 / O-360 / CS, 1600+ hrs, 1st flight Sept. 1999
Outstanding Workmanship OSH 2000, Craftsmanship award AWO 2000
Airport committee chair & AOPA ASNV for Seaside, OR Municipal (56S), www.seasideairport.org
Last Donated January 2022
Old 09-09-2020, 11:22 AM
PhatRV PhatRV is offline
I find a string is an excellent tool to reference a straight line but it can stretch, even for a short distance. Longer distance makes it worse. I use a metal tape measure when I aligned my horz stabilizer because of it
RV8 standard build: 90% completed (90% to go)
Waiting to install wings to fuselage.
Days to Final Installation: 999
Days to AWC: 999
Days to First Flight: 999
Donation paid through 2022
Old 09-09-2020, 11:26 AM
N546RV's Avatar
N546RV N546RV is offline
Same here; I just used a tape measure, hooked onto a corner of the stab. IN my case, I used the corner of the elevator counterweight cutout. Measure from there to a spot forward, do it on both sides, move stuff around, do it over again. I didn't find it to be particularly tedious.
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
