tonyjohnson
There have been discussions about dimming the Icom A200 by using Pin B which is supposed to be connected to the aircraft dimming bus and will reduce the light by half.
My problem is a bit different. There is no backlight at all on my A200. That is true whether or not power is applied to pin B.
So, what do you do to see backlight on an A200. BTW, this radio has been the biggest PIA of all my avionics.
