Another (simple) Arduino project
BigD
Decided on a project for myself to help learn about micro controllers. Nothing cosmic like LiDAR or a DIY EFIS, though. My field (33M) does not have any weather reporting; this thing uses a temp/pressure/humidiy sensor and user input elevation to calculate the local altimeter, DA, and report the temp and humidity. Need to clean up code, figure out a form factor/case, and think of next project...maybe figure out how to make it transmit this stuff?
Thanks to other tinkerers on the forum for unintentionally spurring me on.
==dave==
N102FM
Nice. Now make it show ceilings and vis.
I l$$ked into instruments for this on my station.....then backed out.
You're right about that - the only way to 'guess' a cloud layer would be mathematically, with temp/humidity/lapse rate. Winds should be easy, if necessary. Funny you answered, as I was going back and forth between Arduino and 3D printing, but I chickened out - figured the cost and learning curve would be shallower with micro controllers. Like me.
==dave==
N102FM
Radio for Arduino clone
Some Arduino clones have tiny FCC-approved radios with 10mi line-of-sight range.
Google: Seeedstudio LoRaWAN Grove.
The Seeedstudio board seems to have everything you need for
- ground-based sensors & transmitter
- battery-powered receiver/display in your plane.
Arduino, radio, connectors, battery manager, plug-in sensors, display, code, wiki, forum - lots of good stuff.
Bo
