ICOM IC-A210 Connector - which side is front?
Use the barrier block in the connector to help you identify that and the number order and alpha order on the connector. I believe you will also find numbers and letters on the ICOM connector that will also help. I believe the barrier block is between 8 and 9 and fits into a recess in the card edge.
