Keep VAF
Going
01-18-2022, 11:00 AM
Handheld radio set-up
Hi All,
My RV12 has one radio so I'm looking at getting a handheld. Curious to see what handheld radio you guy's prefer. Also, I'm interested to know if anyone has a handheld connected to an external antenna and what items were needed to set that up. Also, if you have an external antenna for the handheld, where did you locate that antenna?
Thank you,
Jack
Jack
Titusville, Fl
Proud non-builder owner 2011 RV12 N214LA
01-18-2022, 11:47 AM
Jack please explain what you need a second radio for in a VFR plane?
Hans Labruyere
build & sold project Kitfox IV
Project bought & flying RV12 #120742
Donation 2021 paid
01-18-2022, 11:58 AM
been here awhile
Originally Posted by Jcurry
Hi All,
Thank you,
Jack
I've used a handheld as the sole radio in three of my planes and they perform quite nicely when connected to an external antenna. In my case all three aircraft had belly-mounted 1/4-wave whips.
You might look at the Sportys radio, it doesn't require an adapter for aviation headsets which reduces cable clutter and simplifies installation. Also, alkaline batteries provide longer life than most lithium rechargeable packs and die gracefully instead of suddenly like the rechargeable batteries.
Sam Buchanan
RV-6
01-18-2022, 12:19 PM
Hi Sam,
I was looking at the Sporty's PJ2 today. I will probably purchase it. Thanks for your response.
Jack
Titusville, Fl
01-18-2022, 12:51 PM
keep it small
I like the compact form factor of the Yaesu or small Icom. Who needs a VOR or a big screen. Then it becomes my primary radio in the Pietenpol.
Bob
Bob Miller
RV-6A bought flying, GN-1 resurrected & flying
2022 -=VAF=- Contributor
01-18-2022, 12:53 PM
Hans,
Your question seems a little snippy. Why do I need to explain why I would want a back up radio? Seems like it would be pretty obvious....
Jack
Titusville, Fl
01-18-2022, 12:56 PM
I wish my VFR plane had a second radio.. very nice when you want to pick up an ATIS while talking to atc without asking permission to leave the frequency for a few minutes..
Tom
Las Vegas
RV-4 flying…
RV-8 empenage finished 10-2020
Wings Started.. 11-2020
01-18-2022, 02:11 PM
Hi Jack,
I'm nearing the completion of my RV-7 build (VFR Platform) and I've intentionally planned my panel for just one radio. I'm going with the Garmin GTR200B, which, according to what I've read, has a built-in intercom and the capability to monitor the standby frequency, while staying on the active.
I currently fly VFR in a Piper Cherokee and the only purpose for my second panel radio is to check the weather/ATIS, while staying on frequency with ATC. I've always flown with a back-up hand held in my flight bag.
Recently, I upgraded to the Sporty's PJ2 and this will be my back-up radio in the RV-7. I have installed two COM antennas on the belly and run RG-400 coax from both antennas: one to the back of the GTR 200B and the other will be available just under the panel on the Pilot's side to connect into my hand-held via BNC when I need it.
The range of a hand-held when connected to an external antenna is impressive and is enough for me to be satisfied with it as my back up if/when I might need it.
I'll let you know later if this turns out to be a poor plan!
Ryan
Taylor, AZ (KTYL); Builder #74649
RV7 N789YZ - Emp done; SB Wings done; SB Fuse done; FWF done; VFR Panel done; Windscreen done; Prepping for the big move!
XIO-360-M1B built by JB Aircraft Engines
67 Cherokee 180C - Flying
USAFA - Son graduated May, 2022
My flight bag is made by Dewalt!
01-18-2022, 02:20 PM
Originally Posted by ryankhallcpa@yahoo.com
Hi Jack,
Ryan
Thank you Ryan. That is very good information and what I was looking for. Thanks for taking the time to write all that out. I fly in Florida in busy airspace and I just want the redundancy. How do you like the PJ2? Good luck on your RV 7.
Jack
Titusville, Fl
01-18-2022, 02:28 PM
My -12 has a GTR 200, with a standby frequency that can be monitored. I always carry a handheld when flying out of my area. We fly over the desert on long trips and “if” I had to emergency land somewhere outside of cell coverage the handheld would be handy on the trek to civilization.
Live as if you were to die tomorrow. Learn as if you were to live forever.
-- Walt --
Thread Tools |
Display Modes |
