Seattle or PNW Shop or RV owners or builder to help with some fiberglass repair?
tass
Active Member
I noticed that one of the wheel pants on my RV-4 moved slightly out of place, and now has a crack on the bottom where I believe it got too close to the ground.
Can someone recommend a shop who can do some fiberglass repair work around Seattle, or PNW that I can fly to?
If there's an owner or builder that I can learn from, that would be great too! I can get some photos of it in the next day or 2.
Find an EZ or Cozy builder who will likely fix it for you :)
I've still got some glass cloth and resin left over from my build, as well as a grinder if you want to make a quick repair...
206 71 four three 5 2 seven
Thanks everyone! I'll follow up out of the thread and post an update when the job's done.
