Keep VAF
Going
w/a Donation
VAF on Twitter:
@VansAirForceNet
09-16-2023, 11:16 AM
editing software ?
I have a GoPro, but rarely use it because I'm not comfortable/happy with the software for editing the resulting 360 files. I use Apple computers. What editing packages are available for MacOS that aren't rented for $30/mo ?
David B. Hill
N76012
RV-12 #0760
Dues paid through 6-2024
09-16-2023, 02:35 PM
Originally Posted by Dvalcik
I use a GoPro inside the cabin and a insta360 on a selfie stick off of the end of the wing. Clamped to the hand hold. The two off the wing are from the Insta360 3x and the one in the cabin is from the GoPro 9 that picks up audio.
I am finishing up on a selfie stick for the rear tie down - videos coming soon
my youtube channel is @rv12pilot for using different cameras and mounting locations.
Originally Posted by rockwoodrv9
I have a gopro 360 for outside and a gopro 9 for inside. If you want to hear radio can intercom calls you need a wired connection adapter that is easy to hook up but if I remember about $100. It is worth it to be able to hear comments and radio calls especially for a reasonably new pilot like me.
I mounted the 360 under my wing and it works well for me. I can see the gear and pan around as I want. There is distortion because of the lens but you can get some pretty cool videos. The frame grabs for photos are much better than any other camera I have owned.
I understand the insta360 is a good camera too but I have not used one. Let me know if you need any info on how I made my mounts. Have fun!
https://www.youtube.com/watch?v=xKQbVaU6MRo
Photos of your mounts, inside and out, would be appreciated.
So I assume the distortion is "fish eye" with bulging in the middle and tapering narrow on the sides. I would like to avoid that.
Has anybody tried the "hold the phone in the right hand and dip the left wing and shoot out of the left side of the canopy, and then dip the right wing, and shoot out of the right side of the canopy" method?
Does the canopy itself cause much distortion?
09-16-2023, 03:15 PM
Have you flown in a 12?
Why not just try it?
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 890
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
09-16-2023, 04:15 PM
Nope. My factory-build RV-12is is scheduled for sometime in '24. Never flown one. The nearest thing would be a Tomahawk about 15 years ago.
I did own a C-150 for 17 years, and I did use that method, and I would assume it could be done in an RV-12. What about canopy distortion?
I appreciate all of the feedback I have gotten thus far about camera types, camera mounts, etc.
09-16-2023, 08:00 PM
I sent you a PM.
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
2023
09-17-2023, 04:05 AM
outside?
How on earth did you make that movie
Flying a drone along with you, or what?
Hans Labruyere
build & sold project: Kitfox IV
Project bought & flying: RV12 #120742
https://phmon-rv12.blogspot.com/
(Dutch only but the pics might be worthwile)
09-17-2023, 11:57 AM
I made a pair of "RV tiedown to GoPro" adapters for my -7A. If the -12's tiedown threads are the same, this might work. Bill of materials:
CAMVATE 1/4"-20 Male to 3/8"-16 Female Thread Screw Adapter
Mount Adapter Tripod Mount for Gopro Hero
Stainless steel 3/8"-16 bolts, 1-1/4"
3/8" nylon washer (optional)
I torqued the bolt onto the female end of the adapter and made it permanent with some red loctite. Cut off the bolt head and filed it down nice with a scotchbrite wheel. Thread the other end of the adapter onto the GoPro tripod mount. Nylon washer to protect the underside of the wing skin.
These doodads can thread into either of the three tiedown mounts on my plane, one on each wing, and one on the bottom of the tail.
Ryan Drake
Cameron Airpark, CA
https://stiletto.smugmug.com/RV7
Donated 12/16/2022
RV-7A (N12VD)
Never give up on a dream just because of the time it will take to accomplish it. The time will pass anyway.
09-17-2023, 01:23 PM
Originally Posted by HansLab
I sent you a PM with contact info.
Look at the first 15 seconds of this and you can see the shadow of the pole mount under the wing.
https://www.youtube.com/watch?v=wUkdOsWiaB4
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
2023
09-17-2023, 03:07 PM
One slight disadvantage to low wing is that the wings can interfere with photography.
Can anyone share experience in an RV-12 with a camera such as Go-Pro? Did you mount it inside? Outside? Did you get one of those 360-degree view types?
Any recommendations?
I've had good luck with the Insta 360n X3. Still learning a lot, but the possibilities are endless. Here's the second video I did:
https://www.youtube.com/watch?v=fCwxBEYJCao
Larry Anderson
Indianapolis
RV-Super 8 N88XT SOLD
RV-10 QB N38LA Flying
Helicopter Instructor Pilot
Standardization I.P.
Instrument Examiner
U.S. Army Retired
EMS Pilot for LifeLine
At IU Health Retired :-)
Although Exempt,
Donated for 2022
09-20-2023, 09:00 PM
Eyebolt Mount
I use the tie down eyelets with the MyPilotPro swivel mount.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
you can place it on either wing or the tail tie down. Doesn't have much upward visibility, but unless you're trying to do formation video, usually down is what I want anyway. I also just placed one of the adhesive go pro mounts on the canopy just in front of the latch. I don't have the sun shade installed so it's a clear view from behind the pilot/passenger if you use wide angle, but far enough forward to cut that out if you just want the cowling and the view.
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
