w/a Donation
VAF on Twitter:
@VansAirForceNet
  #11
Old 09-13-2023, 07:17 AM
bobg56 bobg56 is offline
Its a good habit to take plenty of pictures before tearing anything down, also to do one carb at a time so you have a reference just in case, glad you fixed your problem.
Old 09-13-2023, 12:05 PM
D-Dubya D-Dubya is offline
Thanks for closing the loop by sharing your findings. Problem found and fixed...and fortunately, nothing really bad happened.
David Welsh
Beaumont, TX
RV-7 N413WD
Old 09-15-2023, 04:49 AM
Jcurry Jcurry is offline
Thanks for the info. Mine also runs rough mid-range (has since I bought the plane) and I have not been able to figure it out. I've checked float weights,
Idle screw adjustment, mechanical sync, vacuum sync, carb to intake manifold o-ring, carbs overhauled, all with no joy. My ignition system is fine. Keeping my fingers crossed...
Jack
Titusville, Fl
Already flying 2011 RV12 N214LA
My youtube channel: Southern Latitudes Sport Aviation
https://youtube.com/@SouthernLatitudesAviation
Old 09-16-2023, 03:53 AM
Default Screw missing from throttle plate
Found this last night on LH carb. Screws in other carb were tight. Removed screws, applied blue loctite and reinstalled. Borescoped cylinders, no signs of damage or missing screw.
Click image for larger version
Jack
Titusville, Fl
Old 09-16-2023, 06:30 PM
funflying funflying is offline
Jack those screws should be peened over to lock them in place. It takes help to do it and I used a steel rod in a vice to back the screw. And a punch to peen the threads.
Saw it done in a Rotax video and just followed their technique.
Patrick Claar
Arvada, CO BJC
RV12, #401, Flying 2013, N612PC
RV6, 1996-2010 sold
Old 09-16-2023, 07:43 PM
azonslow azonslow is offline
I agree with funflying in that we staked those screws when we rebuilt the Bings on our legacy RV-12. However, the latest MMH edition that I could find states:
"Install throttle valve with 2 new slotted head screws M3x6 secured with LOCTITE 603, ensure that it is reinstalled in the same position as marked at removal."
73–00–10
Page 16
Edition 2 / September 2022
Old 09-16-2023, 09:14 PM
BillL's Avatar
BillL BillL is offline
Default Details count.
Kudos to the OP for not only finding the issue, but reporting the cause!! Two thumbs up.
Pictures are helpful for low memory, but correct throttle plate position is clear as day. The plates are machined at an angle so they will fit the cylindrical bore when closed. Once this is learned, one should find it easy to install properly. Back-in-the -day, I used to leave the screws touching but loose, snug with the plate closed, then tighten and stake.
Bill
RV-7
Old 09-20-2023, 06:56 PM
Catbird Catbird is offline
That's EXACTLY how I did it, the second time...
Old 09-26-2023, 08:10 AM
Default She runs smooth now!
After 2 years of on and off troubleshooting, I inadvertently discovered my problem. While comparing another RV12 to mine, I noticed his choke arms are 180 out from mine. I confirmed in the manual that that his are installed correctly. Flipped mine 180 and all is well with the world. I'm embarrassed that I did not catch this sooner. Dog leg should be pointing down not up. 1st pic is wrong. 2nd pic is correct.
ID:	48560  Click image for larger version
Jack
Titusville, Fl
Old 09-26-2023, 06:17 PM
Piper J3's Avatar
Piper J3 Piper J3 is offline
I’m missing something in the translation…. I see your photos and understand that the actuating plate was installed incorrectly, however… it appears that the rotating brass shaft is still in same position when the plate is installed correctly. This doesn’t explain any difference in operation of the enrichment circuit (choke).
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 890
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
