w/a Donation
VAF on Twitter:
@VansAirForceNet
  #11
Old 09-08-2023, 07:13 AM
DanH's Avatar
DanH DanH is online now
I'll modify the statement. Don't use proseal in overlap seams.
Sealing the head of a rivet on the engine side of the firewall is not a problem. Use proseal if you wish. As a general rule, you can put practically anything on the engine side of a firewall without concern.
Dan Horton
RV-8 SS
Barrett IO-390
Old 09-08-2023, 11:15 AM
philcam's Avatar
philcam philcam is offline
Dan,
I'm curious about what your testing found between the 3M FireBarrier 2000 and the Dapco2100.
FireBarrier is $41 for 10oz and Dapco is $196 for 6oz.
Phil Campbell
Eagle's Nest Projects
VAF # 1043
Builder # 82699
DFW Metromess
Old 09-08-2023, 12:25 PM
DanH's Avatar
Not a lot.
Dan Horton
RV-8 SS
Barrett IO-390
Old 09-12-2023, 01:57 PM
hamblin10's Avatar
hamblin10 hamblin10 is offline
So I called tech support and they explained that fuel tank sealant is used only to keep carbon monoxide out of the cabin. This sorta makes sense to me as only the flanges are sealed and not every rivet if we were really concerned about fire.
Eric Hamblin
Private Pilot/A&P/Aerospace Engineer
RV-12iS in progress. N993EZ
Build 121398
Empennage kit completed
Wing kit completed
Fuselage kit IN WORK
Finish kit IN WORK
Owasso Oklahoma
https://eaabuilderslog.org/?s=MYRV12
Old 09-12-2023, 02:46 PM
Brantel's Avatar
Brantel Brantel is offline
Well, for me personally, anytime I am dealing with the firewall I am concerned about fire.
If you have a fire in front of the firewall, it gets bad fast! Just some of those concerns are when stuff heats up and starts melting, off gassing, billowing smoke and burning.
Have had many a firefighter tell me that most people die from smoke than from the actual fire during an incident.
Brantel (Brian Chesteen),
RV-12IS Empennage/Tail Cone Finished, Wings and Fuselage Kits In Progress, Finish kit on order!
Serial #121606, N912BC (reserved)
Check out my RV-12IS builder's BLOG
Check out my RV-10 builder's BLOG (Good stuff for those starting an RV-10)
RV-7/TU, #72823, N159SB Airplane Sold
Old 09-12-2023, 04:22 PM
rv12is's Avatar
rv12is rv12is is offline
Unfortunately, my understanding is that those building as E-LSA don't have a choice. We have to build per the instructions.
Old 09-12-2023, 04:54 PM
N8DAV8R N8DAV8R is offline
An E-LSA builder will sign a document stating that is what they did.
Without remembering exactly what they were, I recall there being at least a few places where this was may have not even been possible due to availability of materials or parts changes.
Nate - Salida, Ca
RV-12is - N8183H
