w/a Donation
VAF on Twitter:
@VansAirForceNet
  #21
Old 04-30-2023, 05:08 PM
Piper J3's Avatar
Piper J3 Piper J3 is offline
100LL is a misnomer... it is not low lead. Aviation fuel contains enough Tetraethyl Lead (and then some) to prevent detonation. Detonation would be as Elon Musk says… rapid unscheduled disassembly. Aircraft engines are built very light-weight and barely remain in one piece as it is. In addition, the high lead content is bad for the 9-series gearbox slipper clutch.
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 890
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
Old 08-26-2023, 11:21 AM
HEB1022 HEB1022 is offline
Originally Posted by greghughespdx View Post
Going forward, the POH we provide is actually printed in spiral-bound, fold-flat book form. They are 8.5" tall, 5.5" wide, and (now) full-color booklets. No more binder. It's compact and quite usable. You can also print it from the PDF to that size or another percentage if you like, of course. The old/original binder style is no longer available.
I'll post a couple of photos of the new style book soon.
Greg,
Were you able to get a picture of the new format POH? Is it now available?
Harry Burnette
Old 08-26-2023, 11:28 AM
thiggins thiggins is offline
Default PDF from Vans RV-12
https://www.vansaircraft.com/wp-cont...H-Rev-18-1.pdf
https://www.vansaircraft.com/service...ng-handbook-2/
Donation 2023 paid
ASEL INST COMM Tail-wheeler
RV-12iS builder (Empennage complete, Wings complete!, Fuselage well under way!, finish kit under way!, Garmin avionics under way!, engine on the way! , shop out of order )
Got a hangar, and moved some large pieces in!
https://eaabuilderslog.org/?blproject&proj=7buPHH99v
Old 08-26-2023, 12:43 PM
Bob Y Bob Y is offline
Originally Posted by HEB1022 View Post
Greg,
Harry Burnette
I’ve seen it, and it’s not possible to replace individual pages when revisions are published. Definitely a step in the wrong direction from my perspective.
Bob Y - builder 12iS
N569TT first flight 2/9/2020
Greenville, SC
#121047
Old 08-26-2023, 12:58 PM
Mitch757 Mitch757 is offline
I agree with Bob Y. The previous format was much nicer and fits the original binder well.
Mitch
Old 08-26-2023, 01:34 PM
I ended up getting an A5 soft-sided binder, dividers and punch. Printed it two sided A5 reduced to 95% on 1/2 sheets (8.5 X 5.5) and it worked pretty well for me. Still larger than the previous version, but at least it can be updated now.
Greenville, SC
#121047
