Keep VAF
Going
w/a Donation
VAF on Twitter:
@VansAirForceNet
03-07-2021, 06:59 PM
Decided to go cheap for my 5.00 x 5's, just because, you know, experimental! Six months, no air added. Takes a little effort to get an air chuck on them, but pretty happy thus far.
https://www.amazon.com/gp/product/B07NQ89SYS
Mike C.
Sierra Nevada
RV-6A bought flying SOLD
Super-8 bought flying
03-07-2021, 07:13 PM
I use those.
03-07-2021, 07:58 PM
Jeez, Mike! And to think they came after me with pitch forks and torches for posting that I wanted to use a non-TSO’d ELT battery!😱😝
03-08-2021, 07:10 AM
I've been waiting over a month now for the three new tubes I ordered from Van's, wound up patching the tube (NLG) so I could fly...I'll order these too, thanks for the info!
03-08-2021, 07:19 AM
Anyone want to rig up a torture test between this Ama.com, a natural rubber cheapie, a normal TSO tube and the 2 butyl $$ aviation tubes?
I assume the key is strength at the valve stem for torture. With proper inflation and no proud mold edges on the inner tire or FOD, the abrasion resistance of long term wear would be a chore to test.
Powder, up.
RV-6, bought from builder.
O-320, slider, carb, mags, FP
03-09-2021, 08:06 PM
Rich,
The problem with a qualification test as you suggest is that you need assurance the manufacturing controls produce a consistent product so your results are applicable to other tubes. They might be consistent properties but you can’t be sure without a significant sample size or some understanding of the manufacturer’s controls.
Rich
03-09-2021, 09:12 PM
Well my last TSO'd butyls had pores in them that leaked flat twice before I found the rascals.
Have a feeling they CAN all work and can ALL fail, not from wear and tear or shock loads or FOD only.
03-09-2021, 10:23 PM
Originally Posted by NinerBikes
You're taking a trip to the moon... would you want the rocket ship built by the lowest bidder, when your life depends on it?
Wasn't that what happened and why the astronauts were worried?
RV-12LR 912ULS 120346
03-10-2021, 09:48 AM
Well that about sums up the entire Apollo program doesn't it? If only there was someone on these boards from NASA to comment....
Stitch
MSgt, USAF, Ret.
RV-8 Dreamer
03-10-2021, 09:19 PM
I’m one of the first guys to go cheap when I can, but it’s about risk assessment. I have used Harbor Freight copper gaskets since an oil weep is not a big deal if it fails, but blowing a tire tube on landing could be very expensive. My tires are lasting about 500 hours, so the expense does not seem oppressive to me to buy aircraft grade tires and tubes. But that’s why they call it experimental. To each their own.
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
