w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 09-12-2023, 06:06 PM
jdelpeso jdelpeso is offline
Default Tips for changing the rubber hoses in an RV12
Some months ago I started changing the rubber hoses.
I changed some of them, but it was so time consuming that I decided to pospone the rest of the hoses
I wonder if someone can share some tips that make the
change not so painful for me
Jose del Peso
RV12
Old 09-13-2023, 07:01 AM
Jose---which rubber hoses are you referring to? The coolant hoses?
The original oil hoses were teflon, and depending on the year of the plane, some of the fuel hoses were also teflon.
Tom
Tom Swearengen, TS Flightlines LLC, Aircraft Specialty Flightlines
Ridgeland, SC
www.asflightlines.com
Old 09-13-2023, 07:33 AM
Tom, I am talking about coolant rubber hoses
Jose
Old 09-13-2023, 09:20 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Use this tool and remove / changeout one hose at a time. Measure old hose and cut new hose to length. Take photos to verify hose routing. You can reuse clamps. Not a hard job....
Name:	Screenshot 2023-09-13 at 11.17.16 AM.png
Jim Stricker - EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 890
Old 09-13-2023, 09:59 AM
Bob Y Bob Y is offline
I’m a year and a half away from having to do this dreaded job for the first time, so I’m asking you guys that have been through it if you had to completely remove the expansion tank to replace the rubber pad under the tank? It’s the one item for which Rotax does not have a silicone replacement (for the iS at least), so if we’re following their guidelines, it will still be an every five year job. Anyway, does the tank have to be completely removed, and has anyone found a silicone replacement?
Bob Y - builder 12iS
N569TT first flight 2/9/2020
Greenville, SC
#121047
Old 09-13-2023, 07:15 PM
np12 np12 is offline
Default hose help
Jose,
Send PM
Old 09-13-2023, 08:43 PM
warmi warmi is offline
Do not re-use clamps - this was a re-used clamp on a carb fuel house , about 3 months after 5 year rubber change.
https://youtube.com/watch?v=kDW1AOBs...gcnToNtdnKikYX
Old 09-14-2023, 07:59 AM
The tool that Jim shows is excellent for the constant tension clamps that should be use with silicone hose. HPS, Pegasus, and a few others has pre-bent hose, with longer than needed legs. Cut to fit, and youre in business.
Tom
Ridgeland, SC
Old 09-14-2023, 08:34 AM
Thank you everybody for your answers
Jose
