w/a Donation
VAF on Twitter:
@VansAirForceNet
  #31
Old 05-07-2023, 09:12 AM
Amadeus's Avatar
Amadeus Amadeus is offline
Completed this SB this weekend. I DID NOT remove the stabilator since I am in annual inspection concurrently and already had the bulkhead cover removed. Instead I opted to remove the two bolts that secure the counterweight balance arm at the stabilator then shimmy into the tail section, twist and pull the counterweight/arm loose, perform service bulletin then shimmy in again to reinstall the counterweight.
Of course I had assistance of someone at the spar to insert the bolts while I was still in tail and able to twist arm as needed to align the bolt holes. Much easier, in my opinion, than complete removal of the stabilator.
Jayson
RV-12iS
E-LSA
“Never feel sorry for a man who owns a plane.” -Charles Morse (Anthony Hopkins) Movie - "The Edge" https://youtu.be/dJD0lB4zRes
"...except during the month of Annual Condition Inspection." -Me (in the hangar)
"My first wife didn't like airplanes." - Gordon Baxter
Old 05-07-2023, 10:29 AM
gossend gossend is offline
sounds great....unless you're pushin 80, creaky and overweight. Basically, me no shimmy no more
Dick Gossen
gossend@gmail.com
Flying: EAB RV-12 with 130 HP UL Power 350is engine. Call me so I can brag about it!
408 499 8587
Old 05-07-2023, 11:07 AM
Amadeus's Avatar
I did not say I wasn't stiff and sore today....
60 years on 6'2" and 205# doesn't make the shimmy easy, but I didn't want to do all the work involved in removing and replacing the stabilator. I admit that at one point laying on my belly, reaching up to twist so my helper could find the bolt hole alignment I was wondering if the EMS would attempt to pull me out feet first and over the fuel tank or just opt to cut the -12 in half just behind the bulkhead.
Jayson
RV-12iS
E-LSA
Old 07-29-2023, 11:36 AM
rv3flier's Avatar
rv3flier rv3flier is offline
Has anyone weighed the counter balance weight? I'm curious if it would be easier, while inside, to unbolt the weight first and then remove the arm. Do the work outside then reassemble in the reverse order. After it's reassembled, then drill through the extra hole in the lead weight to balance the stabilator.
Like some others I"m nearing 80 and have a volunteer RV12 builder to help with the inside work. I hope to start sometime during the 2nd week in August.
Old 07-29-2023, 11:49 AM
jrtens's Avatar
jrtens jrtens is offline
Not that heavy. Definitely easier to just grab it with the weight still attached.
Jon
2019 12iS SLSA
KAWO
Old 08-01-2023, 06:56 AM
rv3flier's Avatar
Thanks for the feedback.
Old 08-21-2023, 06:50 AM
wesvasher's Avatar
wesvasher wesvasher is offline
Default 3D printed fixture
Made a 3D printed fixture that makes drilling these holes a little bit easier:
https://www.printables.com/model/558...-00067-fixture
