Old 01-23-2015, 10:13 AM
kaweeka kaweeka is offline
Default iPad use and placement
I just got an iPad mini and I'm wondering how others use their iPad in the cockpit. Not what programs but HOW- knee pad, RAM mount to panel, suction mount anywhere? Interested in your responses. Thanks in advance.
Dave
Old 01-23-2015, 10:40 AM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
Here is what I see when I do a search on "ipad mounting":
http://www.vansairforce.com/communit...rchid=23138961
Should find all kinds of answers in there.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 01-23-2015, 11:41 AM
JohnInReno's Avatar
JohnInReno JohnInReno is offline
Default Simple knee pad
I use a simple knee pad from Sporty's (about $15) with a Nexus 7 running Garmin Pilot. Velcroed the back of a Poetic cover to attach to knee pad.
John Morgensen
RV-9A N946PM 600+ hours since 2013
Nevada/Arizona
Old 01-23-2015, 11:49 AM
Charles C's Avatar
Charles C Charles C is offline
Default My ipad mini mount
Here is a photo of my panel and I mounted it to the left side. I like it there, it is out of the way and when I am looking at it I can still see out side the plane. Also with it there, my vent is directed on it so that it will keep the ipad cool and not over heat in the direct sun light. Just an idea.
I think I ordered the actual ipad mount off Ebay for around $10 and then you can order the additonal mounts. I had them lying around so that is why I just ordered the one off of ebay.
http://s92.photobucket.com/user/CNF5...ml?sort=2&o=61
Charles & Fran Cantrill
RV-6A - SOLD
Piper Comanche PA-24-250 - SOLD
RV-7A - Sold
Progressive Aerodyne Searey - SOLD
Orlando, Fl.
Flying out of Grass Roots Airpark (O6FD)
ASEL Commercial/Instrument
Commercial Helicopter
Paid 2018 Dues Gladly Paid
Old 01-23-2015, 05:52 PM
n707sm n707sm is offline
Default Using the Universal mount
I have an RV-7a, and use the Ram Universal mount. However, I chose to remove the mounting foot at the bottom, and instead, carefully, slowly (not all at once), flatten about 1" of the round aluminum stock to about 3/16" inch thick, and roughly 3/4" wide (trim as necessary), then drilled a hole in the center of this flat spot for a #8 screw. Using the bottom-most, inner #8 screw on the kick-panel on the passenger side (covering the fuel lines), attach the bottom of the mount there.
For additional support (obviously required), use an Adel clamp around the aluminum stock, and attach to one of the upper #8 screws holding this same panel. No drilling in the aircraft required! ...And it's in a fairly little-used spot.
Then, carefully bend the mount to a central location between the seats (and above the fuel selector), and trim to the best height to allow leg clearance underneath while sitting and climbing in and out, yet not to high to be in the way of any controls, or panel access. Use whatever cradle is best for your iPad. I use one of the sliding, spring adjusting mounts for easy insertion/extraction.
This position works out well, and it's not too hard to route a charging cable (from a cigarette lighter power source -- no, I don't smoke ) under the panel to the iPad (if you install the iPad in the cradle upside down it's a shorter run) without much cable being exposed to catch on things.
One thing to get used too, is the need to go under the iPad cradle to get too the fuel selector - I don't even notice this anymore. Also, keep something like a soft cloth handy to clean the iPad, and also cover it from prolonged direct sun-light while parked. It will heat up and turn off! ...not so
HTH
Michael
Old 01-23-2015, 05:58 PM
unfluencer
Default My iPad Mini installed in the RV-6
Pic at:
http://www.vansairforce.net/_____delete001/sdf89gylh234lkjhlkhasdflgkh.jpg
Set up to *just* clear the canopy when closed.
Standard RAM mount.
Doug Reeves (your host)
  • Available as Contract Pilot (ATP. PIC typed in G-V(450/550) and Phenom 300). Flying resume.
  • Part time: G450/550 and Phenom 300 seat support at CAE (KDFW).
Old 01-23-2015, 10:13 PM
Michael Burbidge Michael Burbidge is offline
Default Nose wheel SB
Charles C,
In looking through the pictures of your airplane I noticed that the bracket that limits nose wheel pivot is on backwards. Just making sure you know there was an SB issued recently on that.
Michael
Michael Burbidge
Sammamish, WA
RV-14A Wings
RV-9A Flying 390 hours!
Last Donation: December 2020
Old 01-24-2015, 07:47 AM
turbo's Avatar
turbo turbo is offline
left side ram mount. best thing since sliced bread. so much info in the cockpit. glass is good.
TURBO YES =VAF= Payed Jan2022
Ed D'Arcy
RV6-A 5,400+ hrs, R-44 1,700 hrs, Helicycle traded for 33 FFR coupe, 300 young eagles flown
Stuart, Fl / East Hampton,Ct / Virgin Gorda, BVI - villa sold.
addicted pickle ball player
Old 01-24-2015, 07:59 AM
right side ram mount just enough info in the cockpit glass breaks and eats into fuel fund
Old 01-24-2015, 09:20 AM
BJohnson's Avatar
BJohnson BJohnson is offline
Default 3 seat rv9a?
Vlad
So that is a how a fighter pilot flies a side by side RV. Stick in the right hand, throttle in the left hand, sitting on the centerline. The wide stance of the rudder pedals leaves a lot of room other systems. This picture cracked me up!
Brice
RV-9A 90897 FLYING
