Desert Rat
With all the Garmin stuff I'm installing, panel space went down, while power distribution needs went up. With that in mind, I'm planning fuse blocks on a swing down tray between the panel and sub-panel, as I've seen others do. Mission critical stuff and anything that might be prone to voltage nuisance trips like motors and whatnot will be on a breaker.
*before we get down in the weeds, i understand that the reason for circuit protection is for the wiring, and I understand how to size a wire/breaker for the load.
*probably not interested in going with the vertical power magic box in place of fuses/breakers- yeah, I get that it's easy and makes for a tidy installation, but I don't like the idea of being AOG because of the failure of one critical box that I can't work on, plus most of the additional features can be handled by the gad27
here's what I'm thinking;
Breakers-
Alt field
P mag 1
P mag 2
Boost pump
Pitot heat
Flaps
Autopilot controller & servos (gmc507 & gsa28 x2)
electric trim x2 (ray allen)
Fuse block /buss 1
Fuse block/buss 2
Fuse block- 1
PFD (gdu460)
transponder (gtr 45r)
AHRS/Magnetometer (gsu25 & gmu11)
engine monitor module (gea 24)
system controller (gad27)
Audio panel (gma245)
IFR GPS (gtn650)
comm 1 (gtn650)
spare
spare
Fuse block -2
Backup horizon (g5)
MFD (gdu460)
Comm 2 (gtr20)
backup battery power input (IBBS)
nav/taxi (flyLED)
strobe/land (flyLED)
cabin lights/panel lights
usb charger
spare
spare
One primary question you may have picked up on based on what I listed above;
What is the consensus of powering each of the fuse blocks from a breaker? I normally wouldn't be crazy about the idea of fuses downstream of a breaker, but it seems like it might make sense here. I'm a big fan of the ability to load shed. It would also be nice to power up stuff individually during software uploads. Putting big breakers upstream of each fuse block accomplishes both of those.
does this pass the sanity check?
Breakers-
Alt field
P mag 1
P mag 2
Boost pump
Pitot heat
Flaps
Fuse block /buss 1
Fuse block/buss 2
Fuse block- 1
PFD (gdu460)
IFR GPS (gtn650)
comm 1 (gtn650)
spare
spare
Fuse block -2
Backup horizon (g5)
MFD (gdu460)
Comm 2 (gtr20)
nav/taxi (flyLED)
usb charger
spare
spare
