David-aviator
I've had 2 incidents recently that really got my attention, I thought something very wrong with the elevator control system. On both occasions it happened on landing.
First time was about 2 weeks ago, I could not flare the airplane normally, it took lots of back pressure and finally just felt like a ratcheting relief as the stick reluctantly came aft. I checked it over after landing and all was perfectly normal with feel and movement of the elevator.
Last Saturday it happened again in traffic pattern, this time half of usual nose up trim kept the airplane in trim and all felt normal - but I know something was not right and cautiously continued the approach and landing. During flare same thing, I could not get the nose to come up like usual and then it just broke free. The nose pitched up but was abled to salvage a fairly decent landing with a little power.
I knew instantly the auto pilot had been engaged!!
In talking with Trio yesterday we concluded control wheel steering engaged sometime just before landing. How could that happen? I con't have the disconnect circuit hooked up.
Well, the culprit has not yet been located but we are reasonable certain the unprotected wires are making ground and engaging control wheel steering. The wires are somewhere under the floor going aft to the servo.
Its not proof positive but Trio engineering and I are in agreement that is what has happened. All the evidence is there I just need to find the wires and shield them or hook them up to a switch.
