Old 04-10-2021, 11:02 PM
rcarsey's Avatar
rcarsey rcarsey is offline
Exclamation Rotax 912iS fuseboxes fuses
I was recently troubleshooting an alternator-out/intermittent issue. In the process of tracing things, I examined the Rotax fusebox mounted on the firewall. During building, I never bothered to open it or even look inside.
Below is a photo of what I found. The engine has 3 hours on it. The two fuses pictured, (I believe, though haven't consulted Rotax manuals yet) protect Regulator A and Regulator B output. It's not clear to me what would have happened if both fuses fell out simultaneously.
I have pushed them back in (with minimal force I may add), and added generous beads of hot glue to make sure they don't come out. I would advise all owners to take a look through the protective frosted plastic next time they have the top cowl off.
Rob Carsey, North Brunswick NJ
RV-12iS (N713) / Completed 12/2020
ASEL, Glider, AGI/IGI, LSRM-I, FCC GROL
Old 04-11-2021, 08:46 AM
Mich48041 Mich48041 is offline
If the grip on fuse terminals is not strong enough to prevent a fuse from falling out,
then the grip is not strong enough to provide a good electrical connection either.
Joe Gores
RV-12 Flying
Old 04-12-2021, 08:56 AM
Don't think I'd use hot melt glue for anything on the firewall.
Or for anything at all important elsewhere on the airplane.
Dave
Old 04-12-2021, 08:54 PM
You might try putting a slight twist in the fuse blades. When I was a young Navy nuke reading the the core tech manual they discussed the tendency of control rods to vibrate in the coolant flow. It was solved by “mechanical bias”, a fancy term for bending to get a good interference fit. Hey, if it was good enough for Rickover you could at least try. Fuses are cheap.
Old 04-17-2021, 02:28 PM
JwWright57 JwWright57 is offline
Thanks for the heads up Rob. I’ve never thought of opening that up.
Jeff Wright, Charlotte NC
Rv-12 started!
Tail 99% done
Wings 99% done
12IS fuse kit 99% done
Finish kit 95% done
Avionics kit 1% done
Dues paid 2020
Old 04-19-2021, 07:34 AM
jcboon jcboon is offline
I had the same problem after my first flight on Feb 6th 2020. It took me quite a while and a lot of sweat to find the (frustratingly simple) cause of the problem. See https://vansairforce.net/community/s...d.php?t=180536
Jeroen
Amsterdam
RV-12iS #121073
Flying Feb 6 2020
Old 04-19-2021, 10:36 PM
rcarsey's Avatar
Thanks. I'm not sure how I had missed your prior post. I reported my (and your) issue, along with our photos to Van's Support so that they are aware of it being more than a one-off builder issue.
I'd think they would want to consider taking action if more than 1 builder is having fuses fall out (in a fusebox that doesn't get opened/inspected routinely).
Old 04-22-2021, 04:00 AM
It does not help that the 'window' is opaque, and that you cannot inspect the innards of the fuse box without removing the lid.
Jeroen
Amsterdam
RV-12iS #121073
Flying Feb 6 2020
Old 04-22-2021, 06:40 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Perhaps you could put small piece (strip) of foam on inside of lid. When lid is in place the foam will press against fuses to hold them in place. Removal of lid allows complete unobstructed access.
Jim Stricker - EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 650
Old 04-22-2021, 09:02 AM
rvbuilder2002's Avatar
This could be done, but if the mechanical (friction) connection of the fuses is not enough to keep them from vibrating out, then I would not trust it to be a good electrical connection either.
If anyone else with a RV-12iS experiences this problem please use the notification procedure outlined in the Maintenance manual to let us know the details.
One thing I would suggest to anyone that experiences this is to immediately recheck the pitch of the prop blades to confirm the pitch angle is within .1 degree of each other, and then get a dynamic prop balance ASAP. It is possible that the grip friction of all of the fuse sockets is acceptable but the one moved was a bit lower than the others which allowed excessive vibration to displace the fuse.
Scott McDaniels
Hubbard, Oregon
