Keep VAF
Going
05-04-2018, 01:07 PM
Mine are riveted in 3 places and a #8 screw in the 4th to hold the clamp, which holds the nylon tubing. I seem to recall there being instructions that said to do it this way.
Ray
05-04-2018, 01:17 PM
Originally Posted by kentlik
(snipped)
Have this to deal with, ideas?
Looks like the windscreen glass let go over the top? Rough up the remnants and glass over it. If you use Sika 209D primer on the windscreen acrylic before you start glassing you'll get a much stronger bond with the epoxy.
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
1200+ hours as of May, 2022.
05-04-2018, 02:43 PM
Thanks for the info! This is part of the fuse that I am working with previous builders holes. The tubing is held by a #8 screw outside of the fairing.
Seems to work ok. I also found that the 3/16 dimple die gave a nice dimple for the screw.
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
05-04-2018, 02:46 PM
Right on Lars! I think that is what I will do! I need to cut back the glass shown a bit as it is free from the windscreen as well. Not all the way down but far enough to be a problem...Sika probably help here as well I would imagine.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
05-06-2018, 07:48 PM
skirts
I have been futzing around with the skirts today a little. I have a flair at the back I need to work out. I think I can redrill the extra set of blocks the canopy frame goes into.
I was using the original's that I thought was good for a preliminary setup but had anticipated drilling a final set. I still have a hint of twist I might try and remove before I
glue the canopy, so slight.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Reason: grammar
05-07-2018, 09:05 AM
I am still working out the canopy frame. I feel it needs to be just about spot on to make the following work ordinal or measurable. SO...back to tweaking the frame.
I found that my right side leg stub that mates with the roller are about 70 thou' proud, this is going to help out a lot with the teeter problem I have been fighting.
Most likely will make it go away altogether, I hope!
You can see it a bit exaggerated in this pic:
Doing this will actually exacerbate my twist problem, DOH! But, I can deal with that now that I am getting my certification in twist removal haha...
Other than that everything else is a mess...
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
05-07-2018, 02:00 PM
I didn't realize how HUGE the passages were in the originals until I made my own.
This helped a lot for fitment, like, a whole bunch!
Maintained my parallel to deck on the side rails as well.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
05-07-2018, 09:30 PM
Canopy
I got serious about the canopy finally after several days if not weeks.
In Oregon when the sun comes out you better be quick! Got up to
70 plus, but not 75.
Before:
During:
After:
When did my hair fall out? Do I look like this? Holy Moly!
This little guy works well and is forgiving. The limiting factor was my eyesight in the sun...
I have a lot left to do but it is a start!
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
05-14-2018, 03:46 PM
Drilled the latch hole
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
05-14-2018, 07:01 PM
Glad to see your going strong there Kent! I wonder if anyone out there actually looks forward to doing the canopy?
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Thread Tools |
Display Modes |
