w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 09-17-2023, 06:25 PM
larywil larywil is offline
Default RV-3 Autopilot
Has anyone ever installed an autopilot in an RV-3? I have yet to find any avionics manufacture include a -3 in their advertising.
Old 09-17-2023, 07:54 PM
I put the Dynon one in my RV-3B, still under construction, though. Paul Dye has the Garmin one in his, which is flying.
Dave
Old 09-17-2023, 09:14 PM
FireMedic_2009 FireMedic_2009 is offline
Are you asking about hardware brackets to mount the servos? The pitch servo is mounted at the bell crank just behind the baggage compartment. That’s the only place I’ve seen a servo mounted. As far as the roll servo, it’s either in the wing at the bell crank or under the seat. On my 3 it’s mounted under the seat
RV-6A IO-320 FP sold
RV3B O-320 160hp
Donated 2018 and continue annually
Old 09-17-2023, 11:42 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Dave
We actually have the TruTrak autopilot customized to work with the G3X. I think it was called the GX Pilot. Has been flawless with both the original G3X and with the upgrade to the G3X Touch.
We rolled our own brackets for both pitch and roll based on how it’s done in other RV’s. Pitch is in the usual spot by the pitch bellcrank, and roll is out in the wing next to the aileron bellcrank. It is very tight in the skinny wing, but works.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 09-18-2023, 08:15 AM
Here's a shot of the Dynon roll servo in my wing.
Click image for larger version
Name:	AP Roll Brackets.jpg
I used the stock Dynon brackets. For the ends of the servo pushrod, I used some plates I made that serve the same purpose but which are lighter than the wide steel washers commonly used.
Dave
Old 09-18-2023, 09:26 PM
JoeLofton JoeLofton is offline
For my install I mounted the Trutrak roll servo on the spar at the right wingtip.
Old 09-19-2023, 07:48 AM
3bythelake 3bythelake is offline
I have the Garmin autopilot in mine. Pitch servo is behind the baggage compartment, roll servo is in the right wing.
