  #11
Old 02-05-2021, 01:07 PM
Bcone1381 Bcone1381 is offline
Gasoline boils at a relatively low temperature. If the gas boils problems result. Pumps move liquid, not vapors for example.
Car gas standards vary from state to state, but 100LL manufactured to standards that control things like its boiling point. More research is needed to know what that point is, but 150F for autos was one result the trusted internet spit out. Winter blend fuels will have a different (lower) boiling point than summer blends.
So keep things that might be a heat sink like the electric fuel pump, and gascolator cool and out of the engine compartment to help make an installation tolerate auto-fuel. Also keep your fuel line lengths as short as possible and away from exhaust. A 3/8" DIA line will move fuel faster over its length than a 1/2" line. You might also insulate your fuel lines and your fuel totalizer hardware, and place a cooling shroud on your engine driven fuel pump.
Maybe this is the reason why one person's aircraft burns auto fuel with no problem yet another one has issues. So, its more to it than compression ratio to determine rubber compounds.
Old 02-05-2021, 01:27 PM
airguy's Avatar
airguy airguy is offline
Absolutely true - and I'm happy to share the path that I took to enlightenment and running 91E10 - but that really should be another thread.
Garden City, TX VAF 2022 dues paid
N16GN flying 1,000 hrs and counting on 91E10; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Pending Repeat Offender - 10 kit is on order. TDI? Turbine? Stay tuned!
Old 02-05-2021, 02:20 PM
BH1166 BH1166 is offline
Default Just say no
To 100LL..... recently running pump gas 80% of the time, 93 octane alcohol free in my 1991 O320 D1A 160 hp. I convert my fuel cost savings to flying faster burning more fuel. AMERICA
Butch
RV6A Purchased N72TX
Old 02-05-2021, 02:53 PM
PilotjohnS PilotjohnS is offline
Default 100LL
Please bring on the 100 unleaded av gas. Cant wait for the lower maintenance (no plug fouling, less slug in oil, etc).
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2022, worth every penny
RV9A- Status:
98% done, 2% left to go
Structure done (less gear)
Electrical/Panel done
Firewall Forward 95% done
Fiberglass 90%
www.pilotjohnsrv9.blogspot.com
Old 01-29-2022, 07:20 AM
David Z David Z is offline
Browsing the internet yesterday, I stumbled across this document from Lycoming. SL270 titled "Extended Maintenance Intervals for Spark-Ignited Engines Operated on Unleaded Fuels".
Seems Lycoming is happy to recommend doubling the oil change hour internal when running entirely on unleaded fuel. Still need to change the filter at 50hrs, but the oil can keep going.
Yes G100ul costs more. Does that offset the reduced cost of oil changes? I suppose it's very specific to each engine and how much fuel and oil it consumes. An oil guzzling O-235 will be a different story than a clean TIO-540 chugging back 20gph.
Click image for larger version
Name:	SL270 Extended Maintenance Intervals for  Engines Operated on Unleaded Fuels_0.pdf
RV8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage assembly, it's a riveting job!
83126
Dash 8 day job is financing the RV8
Donation till September 2022
Old 05-13-2022, 04:06 AM
hoyden hoyden is offline
My foray into running 91 non-ox in my IO-360 ended after about 15 minutes. I had 100 LL in the left tank and mogas in the right. I took off with 100 LL and tried cruising on mogas. The first thing I noticed was a drop in fuel pressure from 24 psi to 7. I turned on the electric fuel pump. This happened 4 times. During the time in between loss of fuel pressure I tried leaning. The engine did not seem to lean as well. EGT was around 1300 and CHT 290-320.
I returned home and drained the right tank. Then I flew to a local airport to fill up with 100 LL. I did verify the right tank filled with 18 gallons.
My mechanical fuel pump is about 10 years old. It pumps 100 LL at 24 psi. Most of the time the pressure is steady but occasionally there are brief fluctuations to as low as 18 psi. I may replace the pump but I am hesitant to try the mogas experiment again.
RV-6 IO-360, CS
Old 05-13-2022, 04:44 AM
wilddog wilddog is online now
Lycoming still recommended oil change at four mos.
Old 05-13-2022, 04:46 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Originally Posted by hoyden View Post
... I may replace the pump but I am hesitant to try the mogas experiment again.
Sounds like you experienced some vapor lock. I'd have a look at the tubing between the tank and your fuel pump. There may be a place where the flow is constrained, and it's causing the fuel to change state from liquid to gas.
Mickey Coggins
Fresh Ukraine update and photos from RV-6 owner Alex 28 June 2022!
http://www.rv8.ch/help-people-in-ukraine/
Please send him a bit of money so he can keep providing food and essentials to civilians affected by the war.
Old 05-16-2022, 06:23 PM
I was surprised to have vapor lock while in cruise. I plan to measure fuel flow from the left and right tanks using the boost pump to see if they differ.
RV-6 IO-360, CS
Old 05-17-2022, 10:55 AM
Reach out to Airguy, posted on Feb 5th. I'd be interested in hearing what he has to say.
As you look over your installation think "Hot fuel. Look where the fuel passes and it distance between warmth or things that touch fuel might get warm. As the fuel heats up it will vaporize at some point (or the fuel pressure will drop which lowers the boiling point) So a 90 degree AN fitting in a fuel line might be a weakish spot.
