Go Back   VAF Forums > Model Specific > RV-9/9A
Old 05-11-2022, 09:55 PM
terrye terrye is offline
Default Pix of throttle cable routing -9A -7A injected with new elastomer nose gear leg
I'm doing some wiring routing through the tunnel and would like some pix of the throttle cable routing on the -9A or -7A with an injected engine (mine is horizontal servo) and Vans new (from 2019) elastomer nose gear leg. Both sides of the firewall but especially the aft side.
Thank you.
Terry Edwards
RV-9A (Fuselage)
2021/2022 VAF Contribution Sent
Old 05-12-2022, 06:43 AM
recapen recapen is offline
I'm in the process of converting my 6A to the new elastomer nose-gear / engine mount.
My FI servo is an AFP vertical unit - my throttle cable had already been routed through the oil-filter cut-out plate and I didn't change the FW penetration with this conversion.
The attach point for the throttle cable ends up being in the stock location that you would end up with by using Vans mount. I used an AFP mount since I already had it - just made a new plate for the cable end.
I can take some more pictures if you think that will help - again, mine's a 6A with an updraft servo...
Ralph E. Capen
RV6AQB N822AR @ N06
"Patience"
Old 05-12-2022, 09:16 AM
All pictures welcome, especially the cabin side of the firewall.
Terry Edwards
RV-9A (Fuselage)
Old 05-12-2022, 09:29 AM
PilotjohnS PilotjohnS is offline
Default Horizontaal
I stuck with the io320 which is horizontal. Here are my pics. I did change the location of the alt air firewall penetration; I could see how the and location would work and i wanted to keep the cables high on the cabin side. All three cables, throttle, mix, and alt air are side by side at the bottom of the "shelf" formed by the oil filter cutout piece on the firewall.
ID:	25746  Click image for larger version
John S
Dues paid 2022, worth every penny
RV9A- Status:
98% done, 2% left to go
Structure done (less gear)
Electrical/Panel done
Firewall Forward 95% done
Fiberglass 90%
Old 05-16-2022, 10:19 AM
Any more pix?
Terry Edwards
RV-9A (Fuselage)
