Keep VAF
Going
04-22-2022, 05:55 AM
i think ''mogas'' is what is in the tank in the ground. it is 91 octane no lead for $3.99/gal at my airport now.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
RV-12 airworthiness cert. 11/30/2021
04-26-2022, 08:33 PM
Has anyone reached out to the factory to see what modifications would need to be done to accommodate the different engine?
Chris C.
Private Pilot
RV-9A Emp Ordered - Feb '22/ Rcv'd May '22
06-01-2022, 07:50 PM
Originally Posted by hpmicrowave
In a discussion with a reliable source at the end of Sun n Fun this past weekend I was told about an ongoing flight test program with a RV9 and a Rotax915is. The source said the upgraded RV9 can easily keep up with the RV fleet at 9k and above. The conversion package his company is working on will be complete with prop, cowling, and firewall forward and will be brought out soon when all the testing and details are complete.
On the other hand this might just be a Rotax POC working with Vans Aircraft developing the firewall forward design details for the RV15??
From my experience with the 915is I believe it's one, if not the most sophiscated reciprocating aircraft engine available today. It's fully computerized with redundant computer, fuel and ignition systems, turbo charged and inter cooled, gets full power to around 15k, computer will always work to get the most efficient fuel power combination with the single power lever. Burns mogas including ethanol mogas as well as avgas. And uses oil like a modern car engine does. Oil changes every 100 hours using unleaded fuel and 50 hours with leaded avgas. It's not cheap but it's operating costs will make it a good option for many folks.
Your source sounds very reliable indeed. Here's a flight out of Sebring with one of the Vans company RV-9s (N179RV) that is registered with a Rotax 915. There were a handful of flights the end of April. This particular flight went up to an altitude of 17k where it looks like the ground speed topped out at 190 kts!
06-01-2022, 09:02 PM
Did you notice the 1,200-1,400fpm climb from 14k to 17k? WOW!
I hope they build a new cross-country airplane around that engine- the RV16 will be a great second plane for me to build.
RV12is on order
Currently flying C-172M, 180hp Airplains
San Antonio
Dues paid 12/21
06-02-2022, 02:08 AM
That RV-9 might even be flying with the 161hp Rotax 916iS. Sebring would be a good place for development flying given Lockwood Aviation’s activities there
I heard the guys at Sling mention that the 916iS will be with GA consumers in the next 12 or so months. See this video from 44mins 40 onwards. https://youtu.be/lcFg7J5lIWw
Ed.
RV-3B G-CCTG - Purchased May 2020
RV-8 G-MIRV - First flight 1 July 2019
RV-6 G-BZRV - Flown the nest.
06-09-2022, 04:39 PM
If I were building a -9 now, I would install a 915 without hesitation. Slightly less HP down low, significantly more HP up high - and that's where the -9 shines in comparison to her short-winged brethren.
The ability to (mroe easily) run Mogas is a big plus, too. Yes, I know a lot of VAFer's run Mogas now - myself included - however, I've had several vapour lock issues depending on blend, the 915, or EFI on a Lycoming, would avoid those issues.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
06-13-2022, 04:24 PM
If Lockwood releases a FWF kit for this, I may just have a nice mid-time IO360 for sale.
That engine fits my mission profile perfectly.
Garden City, TX VAF 2022 dues paid
N16GN flying 1,000 hrs and counting on 91E10; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Pending Repeat Offender - 10 kit is on order. TDI? Turbine? Stay tuned!
Thread Tools |
Display Modes |
