  #11
Old 12-26-2021, 02:00 PM
RhinoDrvr RhinoDrvr is offline
My RV-8 has the strakes as well. I don't know any different, but my airplane is capable of being three-pointed. My friends who've flown my airplane, as well as their own without the strakes have noted quite a difference in the flare.
Evan Levesque
RV-8 N88MJ (Built by Michael Robbins)
Lemoore, CA
Old 12-26-2021, 05:42 PM
claycookiemonster's Avatar
claycookiemonster claycookiemonster is offline
Generally, aerodynamically, for everything you get, you often give up something else. Those strakes are small enough to not be a weight issue, but perhaps a slight speed loss? Clearly, if they assist in three-pointing, they help with higher AOA and slower speeds. How are they when you're tail-chasing your buddy at higher than landing speeds? Has anyone modified their upper intersection fairings in any way to work with the strakes?
If they were without a downside, everyone would have them.
Clay "Cookiemonster" Cook
USAF: T-38, F-111F
American Airlines: 727, MD80, 757, 767, 737
RV8 #81751 project sold
RV8 #81651 project acquired
https://theonceandfutureflyer.wordpress.com/
Donations up to date thru December 2015
"...serenity...courage...and wisdom..."
Old 12-26-2021, 11:00 PM
moespeeds moespeeds is offline
When I was flying with Bruce Bohannon back in October, we accidentally figured out that the tiniest touch of power in the flare seems to break up these vortices. You get a smooth 3 point and no tail wiggle.
Moe Colontonio
Cherry Hill, NJ
RV-8 N495T
Old 12-27-2021, 07:54 AM
Presmini Presmini is offline
Originally Posted by michjor View Post
Cool, found the old invoice, you can order the strakes from Micro AeroDynamics at microaero.com https://microaero.com/?s=strake . You'll need to call them to make sure you get the ones for the RV-8 (5001-1 Left and 5001-2 Right).
Thanks for posting this!
Paolo Resmini
SB RV-8 In Progress since 3/21
Empennage: Complete 3/21
Wing: Started 9/21
http://n679pg.blog
2022 dues all paid up!!
Old 12-27-2021, 08:10 AM
Prepperpilot's Avatar
Prepperpilot Prepperpilot is offline
Mmm? Lots of drag in cruise?
Is juice work squeeze?
Old 12-27-2021, 12:39 PM
D Weisgerber's Avatar
D Weisgerber D Weisgerber is offline
Does anybody have another supplier for strakes, I called micraero and they told me they only sell the strakes as part of a kit that includes vortex generators for $395. I only want to try the strakes.
Dave Weisgerber
RV8 N848DW. Ser#83830 done.
James Cowl
DAR inspection on 7-23-2021
First flight on 7-25-2021
Phase 2 on 9-3-2021
Old 01-03-2022, 10:37 AM
PhatRV PhatRV is offline
Default Roll Your Own Strakes?
Question: If I try to create a RV8 specific wing leading edge strakes, can I create from a mold of the leading edge? Is there any consideration if I plan to roll my own version? The strakes in the pictures don't follow the leading edge profile but I suppose there is a reason for that. Any online reference I should look into?
Thanks.
RV8 standard build: 90% completed (90% to go)
Waiting to install wings to fuselage.
Days to Final Installation: 999
Days to AWC: 999
Days to First Flight: 999
Donation paid through 2022
Old 01-03-2022, 11:17 AM
michjor michjor is offline
Thanks.
Unable to provide any advice on the creating your own, shape or placement - I'm sure the company that sells them tested the fluid mechanics to some degree for safety reasons. They also don't need to be the shape of the leading edge as it serves a different purpose.
I searched ebay for the part number and found these results - they seem to be similar to the ones on the RV-8. https://www.ebay.com/sch/i.html?_fro...trake&_sacat=0
Michael Jordan
RV-8 N114A (Built by JR Davis)
https://www.instagram.com/rveighter/
https://www.youtube.com/user/MyWTFName/videos
Member dues paid up 2022
Old 01-03-2022, 11:46 AM
dpansier's Avatar
dpansier dpansier is offline
The strakes came factory installed on the Cessna T303, would not take much effort to reproduce a set by tracing a paper template.
Bend a 90 on a piece of Aluminum and stretch the small edge to form the shape.
Don Pansier
Green Bay, WI (GRB)
RV-7
Antennas for Experimental Aircraft
www.deltapopaviation.com
