Old 01-21-2022, 09:05 PM
Auburntsts's Avatar
Default G3X GSU 73 Message
Got this message on my non-touch G3X tonight: ďAHRS IGRF data out of dateĒ. Does anyone know what this means, and more importantly what I need to do about it?
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 01-22-2022, 07:29 AM
Walt's Avatar
Walt Walt is offline
Update your software is all to get the current geomagnetic field model.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
Old 01-22-2022, 07:34 AM
Auburntsts's Avatar
Whatís the ramifications if I donít? Iím currently running 12.0 and Iím reluctant to update to 12.3 due to issues that others have had.
PP ASEL-IA
WAR EAGLE!
Old 01-22-2022, 08:21 AM
Walt's Avatar
Iím guessing but magnetic heading errors more than likely.
Old 01-22-2022, 08:24 AM
Longez's Avatar
Longez Longez is offline
Post
What??? The only problem I have seen reported with G3X V12.30 was a self inflicted problem of someone trying to operate their system without first verifying that all devices had completed their software updates.
After loading new software on the PFD, you should always immediately enter configuration mode after the display resets and stay in configuration mode watching the System Information page until all devices are showing the correct software versions provided in the software update.
On a multi-display system, I always load new software to all displays except PFD1 first, then load PFD1 and enter configuration mode as described above. It is only the PFD1 display that updates the software in the other system devices. If you have the capability, power off the additional displays (except PFD1) while PFD1 is updating the rest of the system.
Steve
Old 01-22-2022, 01:34 PM
Auburntsts's Avatar
Steve
I know how to do the update— I’ve had my system for 10 years now.
Anyway I was incorrect on the software version that was causing issues with the SL30 — that apparently was 12.2. So maybe I’ll give 12.3 a shot after I do some more research. Because of the issues with 12.2 I want to make sure there aren’t similar issues with 12.3 as I don’t have a copy of 12.0 to revert back to if there’s an issue.
PP ASEL-IA
WAR EAGLE!
Old 02-04-2022, 10:31 AM
Mconner7 Mconner7 is offline
Is there a link to the steps I need to do to update my software? I have the same AHRS message.
Old 02-04-2022, 11:23 AM
Auburntsts's Avatar
Thereís the download instruction on the Garmin site:
https://www8.garmin.com/support/down...=4451#Instruct
Plus instructions in the G3X install manual,
https://static.garmin.com/pumac/190-01115-01_ap.pdf
Itís very easy. I went ahead and upgraded from 12.0 to 12.3 and I havenít had any issues.
PP ASEL-IA
WAR EAGLE!
