Keep VAF
Going
01-21-2022, 09:59 AM
It's significantly cheaper than that for just the hub check on the Whirlwind, I was quoted $1300 if I recall. If the blades are in good shape that's all you need.
Garden City, TX VAF 2022 dues paid
N16GN flying 1,000 hrs and counting on 91E10; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Pending Repeat Offender - 10 kit is on order. TDI? Turbine? Stay tuned!
01-21-2022, 10:02 AM
Whirlwind
Originally Posted by rocketbob
No reference just had it in my head it was 500 hours. Maybe they bumped it up and it was that to begin with.
I was quoted $2K this week for a blade strip/paint/teflons/reseal for a Hartzell so I suggest anyone shopping for a prop take this into account when making a purchase decision.
The Whirlwind 300 series is 5yr/500 hour teardowns. At least that's what my manual says
Wes Hewitt
RV-10 building
Currently painting
01-21-2022, 01:05 PM
Originally Posted by jcarne
P.S. I enjoy reading your posts! You should start a thread and just occasionally post some awesome pics/ observations from your shop. You could title the thread "Prop musings by Joe". Haha Seriously, I think a lot of people would be interested in reading it.
P.S.S. Thanks for the link to the grease a while back, I ended up just purchases a can from them.
I agree on both counts. I learn a lot from Joe’s posts, and his tip netted me a tube of Aeroshell 5&6. Thanks, Joe!
Tim Lewis
CFI, A&P
RV-10 N31TD - 1650 hrs
RV-6A N47TD - 1100 hrs (sold)
01-29-2022, 11:04 AM
Originally Posted by propjoe
You pump grease into one side and the grease should come out the other side of the hub, or until you have inserted 1 oz of grease. Count the pumps into a shot glass if you are unsure what 1 oz looks like. The most important thing I can tell you is that you need to poke the hole where the grease is to emerge with a piece of safety wire or a paper clip or something similar. The wax in the grease will make a temporary plug, so poke before you grease. You add 1 oz or until it emerges out the other side. That is all it gets until next year or 400 Hours, which ever is 1st.
My comments start of post #19 of this thread.
https://vansairforce.net/community/s...=201837&page=2
Direction is given in Hartzell owners manual 115N
https://hartzellprop.com/MANUALS/115N-0000-A.pdf
Here is a Hartzell Video:
Lubrication starts about 19:00:
https://www.youtube.com/watch?v=LHSWwJzWgRU
Please call Hartzell or contact myself with any questions pertaining to greasing your prop.
The shot glass tip is a good one. My Hartzell manual has a note that 1 fluid oz. is approximately 6 pumps with a hand operated grease gun with no mention of gun differences. There are many different hand operated guns available that pump widely different amounts of grease per pump. The one that I have takes 56 pumps per 1oz.. I read this in the gun’s manual and then tested it in a shot glass. It came out pretty close.
Another interesting observation on my two blade prop was that one blade took the full 56 pumps with no grease exiting the lower open fitting, while the other blade took only 40 pumps until grease emerged from the lower open hole. So one blade took a full ounce and the other only took about a 1/2 ounce. Neither blade sheds grease in flight. Not sure what to conclude, but an interesting point.
05-11-2022, 12:01 PM
Senior Curmudgeon
I reached out to Tiffen Aire and they have several cases of Aeroshell #5 and #6 tubes available plus the ability to process smallish orders. If you need a tube of #5 or #6 Give them a call at:
PHONE :
419-447-4263
I just bought 2 tubes of AS 5 this morning, so wanted to let the VAF world know Tiffen Aire still has some at the moment.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
05-12-2022, 09:36 AM
This seems like a HUGE number of pumps on a grease gun, at least any grease gun *I've* ever seen/used. If I pumped mine nearly 60 times, I'd have a veritable mountain of grease.
You *sure* it's 56 pumps?
2022 Dues paid!
05-12-2022, 09:57 AM
Yep. I measured an ounce from the gun prior to servicing the prop and counted the pumps. It seemed off to me to, so I found the gun’s manual online and verified it. The gun looks no different from other guns I’ve owned, but it is definitely metered differently. That was the reason for my post, so others would know to check their grease guns if they aren’t sure how many pumps deliver an ounce.
05-12-2022, 10:24 AM
Took 24 with my gun.
MED
140236
N435MD
Miss March 2020
05-12-2022, 10:55 AM
Aeroshell #5 or #6 grease.
As of May 12, 2022 at 9:52 AM PST Tiffin Aire only has Aeroshell #6 in bulk & will pump it into zip lock bags for shipment.
CW4 (Retired) U.S. Army
A&P: I pay double dues (it's worth it)
Restored L2-M; flown 7 years & sold.
Owned/maintained PA22-150 & flown for 7 years.
Flew & maintained Mooney Super 21.
Flying & maintain Oregon RV-6, 160 HP since 2010.
05-12-2022, 11:39 AM
For about $17/lb plus shipping.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Thread Tools |
Display Modes |
