Go Back   VAF Forums > Model Specific > RV-3
Old 11-24-2021, 01:24 PM
Default Mounted To Engine Before Hangine the Engine?
Is there a list of things which must be installed on the engine before mounting it on an RV-3B? And hopefully, another list of things that should not be installed prior to that?
Thanks!
Dave
Old 11-24-2021, 01:43 PM
Mel's Avatar
Mel Mel is online now
Thanks!
Dave
The main thing is the fitting for the oil pressure line!
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-24-2021, 01:51 PM
Ironflight's Avatar
VAF Moderator / Line Boy
David - given the very tight clearance between the engine and firewall, I’d mount everything that you can on the back of the engine before putting it in place. Mel pointed out the oil pressure fitting - if you don’t do that, you might literally have to pull the engine to put one on. Everything else will be difficult enough to work on that you might WANT to pull the engine…..
Oil cooler lines, ignitions, prop governor (if applicable) - all are hard to get to on a -3.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-24-2021, 02:18 PM
Dan 57's Avatar
Dan 57 Dan 57 is offline
Mechanical fuel pump?
- ain't the Destination, but the Journey -
www.aerofun.ch
