VAF on Twitter:
@VansAirForceNet
  #11
Old 11-11-2022, 01:56 PM
backcountry backcountry is offline
I just just raised and lowered the outboard pivot points. Thatís the only thing I could find to fix it.
Old 11-11-2022, 02:07 PM
todehnal todehnal is offline
Glad it worked for you.
2013- RV12, Kit #119. N123M First flight Nov21. It's a keeper!
1998- RV-9 tail kit, built and sold
1989- RV-6 tail kit, built and sold
Old 11-11-2022, 03:08 PM
thiggins thiggins is offline
Default Loctite!
Originally Posted by todehnal View Post
Adjusting is simple. Remove the center and outboard bolts, slip the rod end out of the bracket and slide it back in after making your adjustment, then reinsert the bolts. Takes 5 minutes.
I would modify this process to include new Loctite per the approved KAIs from Vans. Thatís what I will do if I decide to go that route. Not doing so could be dangerous (there I said it).
Click image for larger version
Donation 2022 paid
ASEL INST COMM Tail-wheeler
RV-12iS builder (Empennage complete, Wings complete!, Fuselage under way !, finish kit ordered, Garmin avionics ordered, engine ordered )
https://eaabuilderslog.org/?blproject&proj=7buPHH99v
Old 11-11-2022, 03:37 PM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Per my posts above... I should further clarify that in climb I need to add ~ 3 lbs force on right rudder to center ball. Conversely, in a glide, a slight amount of left rudder is required. Ball is centered with feet on the floor in cruise flight. This indicates the the plane is nicely rigged for cruise. Right rudder in climb is need to offset torque and P-factor, as it should be. And in a glide, with engine making no torque, left rudder is needed to compensate.
I love this airplane - 800 hours in 7 years....
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 830
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
